Stolmen and Ekby Compression Bookshelf System
150,208
264
31
Introduction: Stolmen and Ekby Compression Bookshelf System
[Better project-complete photos added.]
An absurd set of requirements leads to a hacked compression shelving system for easy maneuverability and expansion.
Goals
Recently I 'earned' some upgraded bookshelves.  Having casually shopped shelving for a while, I knew I had some rather absurd requirements:
*  easy to break down and transport
*  useful as a free-standing divider or against a wall
*  adjustable to varying ceiling heights
Inspiration
A few years ago I chanced across Julie Scheu's "pogo" free-standing bookshelves.  I wanted them immediately.  Since they were a commissioned piece for a gallery in New York, I opted to build my own version.  In metal.  From ikea parts.
While researching compression shelving (the official vocab, it seems), I found sites devoted to pre-built systems.  Most were for commercial use—boring and expensive at the same time.  Thankfully, a site comparing compression shelving referenced ikeahacker and Lucien's stolmen/jarpen shelves.  Hack-tastic!
I integrated the two ideas using Ikea's Ekby shelves, Stolmen poles & brackets and some alternate parts.  Identifying the alternate parts was a chore, due to Ikea's habit of not providing schematics.  However I'm happy to share the results of my trial-and-error process that will hopefully make things smoother for any other ikeahackers using Stolmen parts.
Let's begin the short 'n sweet tour.
Step 1: Stolmen Poles
Be sure to test the telescoping in-store if you can—I had to return two of the four poles I bought for broken telescoping mechanisms within the poles.
Stolmen poles: $30 each
Shelf finish selection
Ekby's Mossby edition isn't as flexible as the Jarpen edition that Lucien used, which can be cut and stained as needed.  But I preferred the metal look.  To achieve two poles and the suspended-shelf effect, I needed to pinion an individual shelf on its centerline.   To do so, I drilled through the metal covering and pressed wood core.
The metal is very thin and punches through quickly if you're not careful, so take your time.  It also gets hot due to friction, so mind your fingers.  I drilled from the bottom of the shelves toward the metal top, to make sure I wasn't introducing alignment problems.
Ekby Mossby shelves, 31 1/8" x 7 1/2": $30 each
Stolmen brackets
They package a lot of spare crap with these.  Between 4 poles and 16 brackets, I have a whole shoebox of duplicate stuff I never intend to use.
Stolmen brackets:  $15 for a six-pack
I used 32 brackets, half double-tongued for future expansion and half single-tongued for the exposed side.
Step 2: Threaded Tube Ends
I jettisoned the stock Stolmen feet because they look cheap.  I kept the built-in threaded tube ends however.  So I only needed new tube ends for half the project.  Due to Ikea's lack of schematics, it was a challenge to determine the exact interior diameter of the pole with the tools I had on-hand.  I decided to use DrillSpot's selection of S&W TE1-1B Tube Ends at 1-1/2" diameter and 1/2"-13 thread size.  They are actually a hair too small but using double-folded paper rings as a washer kept them in place securely.  I wrapped the paper just below the exposed top and stuffed them in.
1-1/2" tube end:  $8.16 each
Step 3: Threaded Leveling Mounts
Ikea's built-in Stolmen tube ends use a metric(?) size bolt described as an M12 x 1.75.  (Vocab tip:  the second number in these thread descriptions is the 'pitch' or frequency of the ridges on the bolt and is essential to the project.)  With the option to pick new tube ends, I decided to use a more standard 1/2" - 13 thread.  However, that meant I needed complementary feet at different thread sizes.
I chose S&W's "Glide Rite" series.  They come in both thread sizes and can easily handle the load requirements.  They look perfectly decent, too.  Mine came with hard, white plastic pads which work just fine and don't scuff the floor or ceiling.
Step 4: "Sandwich" Bolts
1/4" x 20 x 2 round-top bolts
This is the bolt that runs through the two brackets sandwiching the shelf, which tighten the brackets to hold the shelf in place.  The bottom screw is exposed at 2"—I was tempted to try acorn nuts like Lucien's solution but the effect is negligible.
Bolts:  $2.30 for a pack of three
Last bit about DrillSpot.com:  they offer Google Checkout which means you get significantly cheaper shipping than any competitor.  Other resellers charge as much to ship as the damn parts cost and take a percentage on returned product, too.  Boo.
Step 5: Total Costs
Poles:  4 x $30 = $120
Brackets:  7 x 5-pack (with safety spares) at $15  = $105
Shelves:  8 x $30 = $240
Drill bit: $5
Bolts:  8 x 3-packs at $2.30:  $19
Tube ends:  4 x $8.16:  $32.64
Threaded feet:  4 x $4.75 and 4 x $2.38
Total:  $550 and change for two substantial shelves
Shipping added about $50 for the leveling mounts and tube ends, not including trial and error orders.
Be the First to Share
    • Hand Tools Only Challenge
    • Modify It Speed Challenge
    • Remix Contest
      Remix Contest
    31 Discussions
    jimo.etherisland
    jimo.etherisland
    Question 1 year ago on Introduction
    I see this article was posted a decade ago. Do you still have the box of unused Stolmen brackets?
    oaskul
    oaskul
    8 years ago on Introduction
    I made sure to make the bottom feet flush, and my shelves have been standing and stacked full of books for over 6 months without problems. Thanks!
    Clayfig
    Clayfig
    10 years ago on Introduction
    looks like the poles that your whole project is based on are no longer available i think, you link is dead for sure
    _diyMATT
    _diyMATT
    http://www.ikea.com/us/en/catalog/products/20179940/
    Different color, but looks like the same pole.
    beyonddc
    beyonddc
    Yea, looks like the poles from Ikea is no longer available. Is there any alternative? I am having difficulty to find alternative tension pole from the Internet.
    tiffehr
    tiffehr
    I had trouble finding the Stolmen ones. We all may be out of luck, then. Perhaps Craigslist would have someone selling a used Stolmen line.
    Berkana
    Berkana
    10 years ago on Step 3
     You see that gap between the floor and the bottom of the pole? That's what I'm talking about. Close that gap; the pole should be resting directly on the feet. If you don't, that plastic end piece where the bolt is threaded through will fatigue and fail within a year. It can't take the sustained weight of a load of books.
    tiffehr
    tiffehr
     Ah!  Good call.  I do need to reinforce them.  Now that I have my books up, it gives me a better idea of the weight involved.  I'm going to get replacement tube-ends for the bottom, I think.  It's hard to tell from my mobile phone photos but there's a 'locking' nut between the bottom foot and the tube-end.  So that would be the weight-bearing part, which is still not wide enough should the plastic fail.
    Thanks for adding your concerns!  Very, very helpful.
    Berkana
    Berkana
     My suggestion is to not rely on the locking nut; let the foot rest entirely on the end cap, and extend the tube upwards to lock it in place, rather than extending that bolt downwards to push the rest of the tube up.
    tiffehr
    tiffehr
    So now I have a 1/4"-thick metal washer standing in for a new tube end, in the meantime.   Before I added the washers, there didn't seem to be any ill effects on the plastic tube end (yet) but it was a mere month.
    I also have at least one more entire shelf of books that need a home.  May turn that into a supplemental project on here, depending on how ambitious I get.
    scorby
    scorby
    Reply 10 years ago on Step 3
    I would like to second (and 3rd and 4th) what Berkana said, for exactly the same reason.  I learned the hard way, LFMF.
    bordenkecher
    bordenkecher
    10 years ago on Step 5
     are the polls then tension mounted b/w the floor and the ceiling? so that you're not actually drilling a whole in the floor or ceiling to install the shelving system?
    L-A
    L-A
    Reply 10 years ago on Step 5
     Exactly, the pressure simply keeps the feet in place. That's the big advantage of compression poles :)
    icerabbit
    icerabbit
    Love the project.
    However, without additional fastening - like a hidden attachment arm / bracket somewhere higher up, securing it to the wall behind it  - I don't think this is a safe setup.
    I have sincere doubts this will not tip over at some point, unless it were secured with flanges / feet with screw holes at the floor & ceiling. You can't set much tension so as to not damage the ceiling, ...
    Just my cautious 2c.
    56dustbunny
    56dustbunny
    I really wanna do this but it comes out to be pretty pricey, awesome hack. I'm gonna keep this bookmarked for future project. Great choice of beer to work with :)
    freakshow17
    freakshow17
    In regards to oyur DOGFISH HEAD BARLEY STOUT - I believe that is an official Irish Unit of Measure
    urwatuis
    urwatuis
    seems to me the inexpensive alternative is to use 1.5" PVC pipe, 12" wide pine shelving, and hose clamps. It may not have spring loaded tension poles but I think it would be possible to have adjustable poles using threaded pipe fittings and threaded rod. I would try 5/16ths or 3/4 threaded rod for adjusting the feet with strong support. A can of silver spray paint would give a nice metal look if thats what you like. I bet you could do the same project for $50 or less per shelf unit.
    chello2k9
    chello2k9
    I would like to see alternatives material used, the price of this shelf is a little much, but the shelf itself looks nice.
