Stone Fireplace for Theatre Prop
Intro: Stone Fireplace for Theatre Prop
I'm working on the set for "Into the Woods" and started with Cinderella's fireplace.
STEP 1: Big Sheet of Styrofoam Insulation
I started with a 4x8 panel of insulation styrofoam found at Home Depot. I cut it to a 4x6 piece(using the extras for the sides) and sketched out the front. I carved the brick shapes and peeled the plastic covering off. After cutting out the opening, I carved smaller bricks for the back of the fireplace.
STEP 2: The Power of the Heat Gun!
So, this is the cool part....if you melt the foam with a heat gun, you can soften the edges and melt the styrofoam appearance. This give you the brick and stone texture also.
STEP 3: Base Coat the Foam
Stick with water based paint...spray paint will melt the foam. I used flat latex interior paint. Then faux finished the stone, brick and wood.
STEP 4: The Mantle
This stuff can even be faux wood! You just carve and melt to your desired effect!
STEP 5: Back and Front
I used black card stock and gorilla tape to hold the pieces together. The whole thing looks like it weighs tons but is only about 5 lbs.
11 Comments
Kimiaz 1 year ago
happyhill9 8 months ago
Duct tape is the answer...to most of life's problems in fact LOL! And glue guns!
happyhill9 1 year ago
sanfordarts4kids 8 months ago
I just say this, sorry for delayed reply. It was such a long time ago, I'm not sure. But yes, most definitely used more than one sheet. For the mantle, I cut the sheeting and made a box out of it, if that makes sense. look closely at the last picture, maybe you can see the seams?
Woodlawn60 5 years ago
Hello again, did you add any coating to strengthen the fireplace after painting?
happyhill9 5 years ago
nope. It was for a short run of Into the Woods. No long term protection needed.
Thanks!
Hi - What did you use to carve the fireplace bricks? Thanks!
I just used a mat knife. using the heat gun after the cuts made all the difference to smooth out the styrofoam.
