Introduction: Storage in a Solsta Pallbo Footstool
Have additional space storage at your home. Make the most of some old footstool to be an extra storage space.
Step 1: Materials
- Your old Ikea footstool
- Some wood scraps (I had a wood panel 1 cm thick)
- White glue-Staple gun
- Fabric of your choice
- Wheels-Nails or screws
Step 2:
- Remove footstools cover and cut the tiny legs. Keep the legs, you will need them later.
Step 3:
- You have now two empty boxes.
Step 4:
- Cut a piece of wood panel to use as the box lid cover.
- Fix the short legs with screws. This will prevent the lid from falling out of the box.
Step 5:
- Cover the box with the fabric of your choice.
- You have to do it patiently to have a good result.
- Have extra attention on the edges.
Step 6:
- Put a glue on the lid you made before, then put the foam.
- Make sure that it stick well.
Step 7:
- Now it's time to cover the seat.
- Use the fabric you used on the box in step 5.
Step 8:
- Add wheels at the box bottom. These are Ikea's Slugger.
- Make sure to attached it well.
Step 9:
- Double check your work and see to it that everything is placed correctly.
Step 10:
- Finally, you've got two mobile footstools that can be used as your extra storage space.
