Straight and Curved Cutting
Intro: Straight and Curved Cutting
Bandsaws are useful for making both straight and curved cuts.
STEP 1: Making Straight Cuts
Every band saw has some amount of drift. While cutting straight with the blade, it will pull to one side or the other.
- Adjust the angle of your work to make a straight cut.
- Using the fence can help to make a straight cut.
STEP 2: Making Curved Cuts
Blades have a minimum cut radius depending on the width of the blade.
- Forcing a blade to make too tight of a radius will result in friction that heats the work and blade, causing damage to both.
- Make relief cuts to create a small radius.
- When making relief cuts you must stop the blade completely before backing it out.
