Introduction: Sugar Skull Wall Hanging for Halloween
Find me on YouTube HERE!
100's of my Tutorials can be found HERE!
I decided to use some of the leftover pallet wood from the doghouse and create a Halloween decoration. It's a Sugar Skull Wall Hanging.
You will need:
- Scrap wood
- Glue
- Screws
- Stencils
- Acrylic paint
- Stencil brush
- Screws
Step 1: Cut Four Pieces of Wood Cut to Similar Lengths.
Step 2: Cut Two Pieces of Wood That Are Cut Slightly Shorter Than the Size of the Previous Four Put Together.
Step 3: Put Glue Onto the Two Back Pieces and Apply to the Back of the Four Pieces Put Together.
Step 4: Screw the Two Pieces to the Back of the Four Pieces - It Will Keep Them Together. I Used 8 Screws. Make Sure They Are Not Too Long. You Don't Want to Drill Through and Have Them Poking Out the Front.
Step 5: Using a Gray and White Acrylic Paint, Mix With Water and Give the Wood - Front and Back - a Wash. Allow to Dry.
Step 6: Stencil the Skull Onto the Wood. My Stencil and Crossbones. I Taped Them Off, So I Wouldn't Stencil Them Also.
Step 7: Once Dry, Use Other Stencils, or Parts of Other Stencil to Create Patterns and Designs on the Skull. Make It Colorful.
Step 8: I Used a Flat Brush to Paint Teeth.
Step 9: I Used a Golf Tee to Make Small Polka Dots.
Step 10: Stencil Roses Around the Skull.
Halloween Decor Contest
2 Comments
7 years ago on Introduction
Wow it turned out so pretty! Here's an instructable on how to use the editor in case you want to get rid of that extra blank step: https://www.instructables.com/id/How-to-Make-an-Ins...
Thanks for sharing!
Thank you!
