Introduction: Sugru Feet Knife Sharpener
Step 1: Prepare Sugru
Open mini-pack of sugru and take 1 of 4 large pea sized pieces and work it as instructed on pack. Then roll in palm to form a ball
Step 2: Apply Feet
Gently press 1 ball of sugru into each corner of the underside/base of the sharpener.
Step 3: Leveling Feet
Turn sharpener over and apply pressure over a flat surface. I used a laminated tabletop. I recommend laying a piece of plastic/saran wrap between sharpener and tabletop to avoid sticking. I gently applied pressure, reshaped as necessary with my finger and repeated until results were as desired.
Step 4: Curing
Simply turn sharpener upside down to allow sugru feet to dry. Should be around 24 hours as advertised on packaging. Mine took about 16 hours but results may vary based on the thickness and amount of sugru used.
