Sump Pump Water Level: the Software
Intro: Sump Pump Water Level: the Software
This is the second part of my sumppump water level sensor.
You can find the first part on how to built a water level sensor, here:
https://www.instructables.com/id/Sump-pump-water-level-The-hardware/
Needed:
-Raspberry Pi with
Apache
PHP
Sendmail or postfix if you want a email warning.
What the software will do:
The command part
This part is invisible to the user and is (and should be ) independent of the webpage.
Using cron, it will read the water level every minute and save the information to a file. If the water level reaches a certain level, an email will be sent. This is the most important part.
The Web page
In this part, the web page reads the information from the file written by the cron job and displays an image of your pit.
Needed:
-Raspberry Pi with
Apache
PHP
The command part
The Web page
STEP 1: Download and Copy the Software
Download the zip file and uncompress it to the webfolder of your Raspberry. I recommend creating a subfolder at the root of your www folder. Typically, the folder path is /var/www/sumppump.
STEP 2: Ajust the Preferences
Open the file "chklevel.php" with a text editor and change the line 3 to reflect the path to the folder where you copy all the files.
chdir('/var/www/sumppump/');
Save and close the file.
Open the file "preference.php". All the preferences are explained in the comments.
The $levelamber and $levelred variables change the color of the led on the webpage and sends an email to the $to variable.
Be careful: If you set the $preferunit to cm, be sure to set all other measements to cm. The same thing applies in reverse cms to inches."
Refer to this images for the definition of some variables
STEP 3: Schedule the Cron Task
Connect to your Raspberry as root and type this command to edit the scheduled task
crontab -e
Add this line to your crontab file:
* * * * * php /var/www/sumppump/chklevel.php
This will instruct to run the php script at every minutes of every hour of every...
Save the file with ctrl-o and ctrl-x to close the file.
crontab -e
STEP 4:
Voila. If you type in http://myserver/sumppump in your browser , you should be able to see your sumppump.
Note that it's not really a dynamic image of your pit. In fact, what compose the image is a table of three row containing a top image with the sensor, a middle one with the grey background, and a third one with the blue background. The height of the row is determine by the level of water.
*** This code was test in my system only. If you encounter any bug, please write a comment at the bootom of the page.
20 Comments
MikeB1956 6 years ago
Amendments to post: Sorry id errors
I
made a different setup connected to a 12v battery.
The setup is on all
the time and the battery is charged by a solar panel. There is a vertical float switch down the pipe which initiates a relay
to switch on a 12v diesel pump to extract the water. The water trickles into the sump which makes the pump jump in and out
about every 2/3 seconds. Can I include your sensor to monitor the water levels
and control the pump using a 12v battery?
Hi There
is this post still monitored? Just found it.
I Like this little project. I want to take it further by connecting an extraction pump by switching on a 12v fish tank or diesel pump to start pumping out the water (a) when it gets to a high level and (b) switch off the pump when the water level reduces back to the low level.
I made a different setup connected to a 12v battery. The setup on all the time. There is a horizontal float switch which initiates a relay to switch on the pump to extract the water but it jumps in and out every 2/3 seconds. Can I include your sensor to monitor the water levels and control the pump using a 12v battery?
Scottraspberrypi 8 years ago
Hi Luc,
Thanks for posting this guide! I'm having trouble with the code. Could you help me? I'm having many issues, but I'm currently troubleshooting. When I try to run chklevel.php directly I get the following message
pi@raspberrypi /var/www/sumppump $ sudo php chklevel.php
sh: 1: /var/www/sumppump/sensor.py: Permission denied
PHP Notice: Undefined offset: 0 in /var/www/sumppump/chklevel.php on line 13
Mesure final -11cm
Mesure final -4.3pouce
0 have been send sh: 1: /usr/sbin/sendmail: not found
Message cannot be send
Luc Moreau 8 years ago
Change permission of sensor.py to 777 or 755. All other error are because sensor.py cannot execute.
And make sure you can write to result.php
AnthonyS86 8 years ago
Now that I have been able to measure, I don't think it's measuring correctly. I measured about 7 inches of water, but it displays 11.4 inches.
Substract 4,4 from $compensation
Line now reads: $compensation=-4.4;
But it is still about 4-5inches too high.
Thanks, that clears some stuff up. For my cron I would run:
3 * * * * /path/to/php /var/www/html/chklevel.php
I tried running the script manually, and it puked out some errors:
pi@pi /var/www/html $ ./chklevel.php
./chklevel.php: line 1: ?php: No such file or directory
./chklevel.php: line 2: //: Is a directory
./chklevel.php: line 3: syntax error near unexpected token `'/var/www/html/''
./chklevel.php: line 3: `chdir('/var/www/html/');'
is the $deep in cm? Is that from sensor to bottom of pit? Also, what does compensation equate to? Should that be preset as well from 11? Is that in cm or inches?
Hi Anthony,
chklevel.php is a php file, not a bash. If you want to run it manually, do:
php chklevel.php
I assume you have apache and php install on your rasp.
Yeah, that worked, thanks.
Shouldn't this work as a cron? 3 * * * * /etc/php5/apache2 /var/www/html/chklevel.php
I also moved the sensor, and it never changed depth, it always said this:
pi@pi /var/www/html $ php chklevel.php
sh: 1: /var/www/html/sensor.py: Permission denied
PHP Notice: Undefined offset: 0 in /var/www/html/chklevel.php on line 13
Mesure final -11cm
4
4 have been send .The maximum of email have been reach
Change permission of sensor.py to 777 or 755. All other error are becasue sensor.py cannot execute.
for cron, instead of
try:
If you can run php /var/www/html/chklevel.php ,then cron can do it to.
That worked, thanks! Also, any idea on these?
Do you know how accurate the sensor is? I will get crazy readings like:
Measure final 585cm
Then I re run and it's 53cm, which is closer to accurate. Do I need to do anything so it will start measuring the depth of water? Have you found a way to retain results, so I can track trends and retain a little history?
Check the image at step 2. It will give you the meaning of all the variables. If, for some reason, it's not acurate, add or substract the difference of reading you got. Also, You can set the unit of measure to cm or inches in the preference file.
Once you measure in real life an modify the $compensation variable, it should be pretty acurate.
There we go, that is working well now. Any chance of keeping any history? Say for the last 24 hours? That would be cool to see.
My last question is this value:
$compensation=-11;
What is the compensation for? Is that the # for how low the water will get once the water is pumped out? OR is it the distance from the top of the pit (or $deep) minus where the sensor sits? Is it in inches or cm as well?
I also noticed $deep needed to be in inches, not cm.
$compensation is ithe distance from the top of the pit minus where the sensor sits. -11 was my own. And you can add or retreive in case it's not acurate.
I cannot test what is the error of the $deep value, my system is not fonctionnal, I need my rasp for other project.
no worries, was compensation -11 in cm or inches? I assume cm :D .. so far looks to be working great now that I added it as root cron.
Would be cool if you could add some historical graphs of data. My programming is probably not good enough to be able to retain the data, and then display it in a nice graph.
Hi anthony,
Cron is require to run the file chklevel.php. every minutes. The procees is not heavy on the processor, so, run it every minutes.
What chklevel.php does is:
- run a python script to read the water level.
-Compare the result with the max level you enter in the pref files.
-Write the result to the files result.php (make sure the file is R/W 777)
-Send an email if you have reach the maximum water level.
you have to edit:
-line 3 of the chklevel.php file. It have to reflect where the php files are.
-You should edit all the variables in preference.php. If the reading is incorrect, ajust the $compensation variable.
I am a little confused here, what do I need to edit? I have gone through all of the files, edited what I think I should, GPIO trig/echo, directories, etc. What needs to be cron'd? How often? Where does the data go?
budpi 8 years ago
I am not having any luck. My Measurements are 24" deep pit, My Sensor is 20 inches above the pit. And, currently my water level is 4.5 inches. When I load up the page, those number are in no way reflected or translated.
