Introduction: Sundial From Scrap Wood
How to make a sundial from two pieces of wood found in a trash can
Step 1: Get Wood
Get a sturdy piece of Plywood. I found mine in a nearby trash can
Step 2: Cut Out a Circle
Cut a circle out of the wood. Mine is about 8 inches but you can make it any size you want.
Step 3: Glue to Stand
With another piece of wood, cut it at the angle of your latitude. For example my latitude of my location was 34, so i cut the stand at 34 degrees.To find your latitude just look up Latitude Longitude calculator. (use the latitude part though)
The reason you need your latitude is so it will be parallel to earths axis. If you use any random number, your sundial will be off time.
Step 4: Add Gnomon
Glue a straight sturdy object to the center of your circle this will be the Gnomon of the sundial
A Gnomon is the piece of a sundial that when the sun hits it, it projects a shadow onto the sundial
Step 5: Add Time Lines
Now look up and print out a Equitorial Sundial guide. Use this to draw the guide line onto your sundial.
Here is an example of a equatorial sundial guide, Used by permission of The University of Texas McDonald Observatory.
http://stardate.org/sites/default/files/pdfs/teachers/EquatorialSundial.pdf
Step 6: Stain
Stain the Wood
Step 7: Paint
Retrace the lines and Paint numbers onto your sundial. From left to right go 6,5,4,3,2,1,12,11,10,9,8,7,6 and now your done!
Step 8: Place Sundial
Place the sundial with the Gnomon facing TRUE north, not magnetic north.
Step 9: How to Use
If you placed the Gnomon facing true north, when the sun hits the gnomon it will cast a shadow on the numbers on the sundial. The numbers correspond with the time.
