Sundial Watch: the Original Smartwatch
Intro: Sundial Watch: the Original Smartwatch
With all these newfangled smartwatches coming out, perhaps it’s time to get back to the basics. The sundial watch is the original smartwatch, with location specific design that utilizes the power of the sun to tell time. No batteries, no apps, no accelerometer, just classic design. Used for millennia, the sundial is the tried and true way to tell time, connecting you to the natural cycles of the sun. Your Sundial Watch will never run out of batteries or need a recharge, but cloudy days could pose a problem.
The 3D printed Sundial Watch Collection combines the latest in digital fabrication technology with ancient knowledge of the sun’s movement. The Sundial Watch allows you to escape “digital time” and the anxiety created by the constant seconds ticking away your day. The Sundial Watch focuses your attention on light and shadow, developing a relationship with the sun and a more fluid perception of time.
The Sundial Watch Collection includes four designs personalized for your location and lifestyle. Each Sundial Watch is made specific to your geographic coordinates, adjusting the gnomon and angle of the hours. Using a resin-based Objet 3D printer, each watch is crafted with digital precision and made from a fused combination of a flexible material in the watchband and hard material for the watch body. All watches contain a compass inlay to orient north and keep you moving in the right direction.
STEP 1: The Sundial Watch Video
STEP 2: Historical Precedents... Go Ancient!
From the Flintstones to 16th and 17th century Germany, portable sundials have been used as fashionable timepieces. The Sundial Watch Collection draws inspiration from the intricately crafted Ivory diptych dials made by the famous sundial and scientific instrument maker Leonhart Miller. These sundial could be set for use in various latitudes, making them helpful for merchants and travelers in Renaissance Europe. With the Sundial Watch you can go ancient! They were on to something in Egypt all the way back in the 13th century B.C..
STEP 3: Making a Sundial Watch for Your Location
To be accurate, sundials need to be calculated for a specific local geographical latitude; the angle of the gnomon must equal the local latitude and aligned with true North. The Sundial Watch Collection are all horizontal sundials, with the exception of The Traveler, which is a diptych sundial, a combination of a vertical and horizontal sundial. While equatorial sundials have evenly spaced hour lines that are 15 degrees apart, horizontal sundials must calculate hour lines with the following formula:
tan(H) = sin(L) tan(15degrees x (t))
Where, L = latitude, H = angle between a given hour-line and the noon hour-line, t = the number of hours before or after noon
Adjustments:
- Daylight Saving Time Correction: Adjust time by one-hour
- Time-Zone (Longitude) Correction: Standard time zones are 15 degree of longitude and each degree equals 4 minutes of time.
- Equation of Time Correction: Sundial readings will need to subtract or add time due to the elliptical orbit of the Earth (see attached image).
- True North Correction: The Earth's magnetic pole, read by a compass, doesn't correspond to a Geographic North Pole, and must be adjusted by geographic location (see attached image and reference below).
Note: A sundial for one latitude can be adjusted for use at another latitude by tilting its base upwards or downwards by an angle equal to the difference in latitude
References:
- (True North) http://www.princeton.edu/~oa/manual/mapcompass2.sh...
- (Sundial Making) http://www.sundials.co.uk/projects.htm
- (History and Description) http://en.wikipedia.org/wiki/Sundial
- (Instructables) https://www.instructables.com/id/Pocket-Sundial-1/, https://www.instructables.com/id/Diptych-Sundial/, https://www.instructables.com/id/15-minute-paper-cr...
STEP 4: Designing Your Sundial Watch
Designing the Sundial Watch Collection, I first started in 2D, creating the outline of the watch body and band. I then drafted the hour lines and gnomon of the sundial following the procedures outlined in the previous step.I then researched sizes and types of compasses to inlay before completing the 3D modeling. The watch band and moving hinges were slightly offset with a gap, while the black text was Boolean subtracted from the solid watch body. This is important when preparing the file for a 3D print. .
If you don't have a 3D printer, no problem, there are numerous online services available that usually just require that you upload an .stl file. Attached are my .stl files that can be downloaded.
Reference:
- (3D Print Service) http://www.shapeways.com/create
STEP 5: 3D Printing Your Sundial Watch
I used a resin-based Objet printer with materials Vero White and Tango Black. The Objet printer uses a support material that allows for varied shapes and spacing between structural members. After printing, the support material is cleaned off by hand and with a high-powered water machine.
STEP 6: The Classic
“The Classic” offers traditional sundial design with a full watchband flange for replacement and customization. The watch interior contains a 20mm air damped compass with an ultra-low friction bearing for fast and precise readings.
STEP 7: The Sport
“The Sport” is a modern take on traditional sundial design, offering a sleek unified watch body and band with a flexible gnomon dial for those with active lifestyles. The watch interior contains a 20mm air damped compass with an ultra-low friction bearing for fast and precise readings.
STEP 8: The Traveler
“The Traveler” is diptych sundial modeled after the famous 16th and 17th century pocket timepieces made in Germany. The Traveler can be customized to include the latitude for up to four cities, making it an ideal choice for business trips and vacation. The watch body contains a hinge and latch for smooth opening and closing. A string and stopper design allows the adjustment of latitude with ease. The watch interior contains a 5/8” diameter magnetic aluminum compass.
STEP 9: The Adventurer
“The Adventurer” is designed for the outdoors. A sleek unified watch band and body opens with a hinge to reveal a flexible and replaceable gnomon dial. A 1/2” diameter magnetic aluminum compass on top keeps you moving in the right direction.
STEP 10: Have Fun, Get Some Sun!
The Sundial Watch needs sun to operate (or bright moonlight), so get outside and have some fun! Make your own and join the emerging sundial watch community.
31 Comments
Portaldominates 8 years ago
I would love to make this! The only problem, I don't have a 3D printer. :(
Athul Krishna 8 years ago
Same here bro.
photoelectron 9 years ago
Great idea, and thanks for sharing the designs. Worth mentioning, this won't work with bright moonlight (as suggested in step 10), for obvious reasons...
bethany.dougherty.52 9 years ago
How did you print the numbers to go on the watch face? They seem to be two separate files rather than 1. Also I soooo vote for a version that has the pointer able to fold sideways so it is not sticking up until you need it to, but isnt a totally seperate piece that you have to stick in. Love these!
iam_maker_leo 9 years ago
Great....
Really it is a orignal smartwatch....
I like "The Traveler"
hagar7044 9 years ago
gkapriel 9 years ago
A sundial at a particular latitude in one hemisphere must be reversed for use at the opposite latitude in the other hemisphere. Check out the link in Step 3 under "History and Description" for details.
I think I want all of it!
Tigger14120 9 years ago
I WANT ONE! (The Traveler would be nice) Christmas is coming, and this would be a terrific gift for us old fogies who feel a little behind in the tech world. Do you get a commission or something if I would take your downloaded file to an outside printing source? I mean, I appreciate reading instructable files even if I probably would never make one, but many of these ideas are potentially commercial products and you should benefit from your intellectual property.
This is free to share and modify. It's part of the Creative Commons as are many of the wonderful Instructables. So, please do download and print your own and join the Sundial Watch Community!
Sergey Chernyshev 9 years ago
This is asking for OpenJSCAD web app with location detection to produce downloadable models!
budharpey. 9 years ago
Very, very cool project:)
Can you tell me what the dimensions of the smallest and the biggest model are?
I am currently building the "60$ Ewaste 3D Printer" which is also an instructable on this site. Only it has dimension restrictions of 4x4x2cm... Would that be enough for one of the models? This smartwatch would make an awesome first print project for the ewaste printer:-) Possibly I could also scale everything down a little bit..
Hey Thanks. The Ewaste 3D Printer looks amazing. It would be awesome if you printed a Sundial Watch. I recommend printing "The Classic" since it has the simplest geometry and you can add a separate watch band. The dimensions are bigger than 4x4cm, so I scaled it and added an .stl file called "SundialWatch_Classic_Modified" that you can use. Of course, you will want to create your own Sundial Watch top eventually to get a location specific design. Let me know how it works out.
Thanks a lot for adding the modified version!
I will post how it came out as soon as I will be able to do it!
OrienteeringGuy 9 years ago
Input your zip code or lat / long to get your exact magnetic declination at
http://www.ngdc.noaa.gov/geomag-web/
I have no printer, but I'm going to try to make one from walnut and a nice old watch strap.
astromatz 9 years ago
Hi gkapriel, this is not only a very well done 3D printed item but just as much a perfect video presentation - so perfect it makes you want to order one on the spot... Apropos: I don't have a 3D printer and I am not likely ever to own one (I am 69). So I wanto ask: Do you know of any one who is going to make series of these watches for sale? Thanks for listening / reading.
dougstrickland 9 years ago
There are several online services that will do exactly that. You upload the file, select materials, colors, etc., and they 3d print and send you the parts to assemble. Search for 3d printing services. Or checkout Ponoko here: https://www.ponoko.com/
ibenkos 9 years ago
Thanks for the comments everyone. I'd love to hear if anyone 3D prints a Sundial Watch or makes their own design. I would have liked to make a Spherical Sundial if I had more time.
dr_jing 9 years ago
