Sunflower Earring Display
Intro: Sunflower Earring Display
Here is a nice looking way to keep earrings organized. Its fairly cheap, and it recycles scraps. Onward!
You will need:
a sturdy piece of cardboard, at least 7x7 in.
*optional- another 7x7 piece of cardboard
some screen or felt, at least 6x6 in. any sort of material that you can easily get an earring through, and be tough enough. Old rusty wire screen would give a cool look.
paint (i used yellow for the sunflower, but it can be any color)
sharpie (i used brown)
pencil
a needle, or something to punch a small hole in the cardboard
string
glue
box cutter
scissors
either a compass, or some circular object to use as a pattern (i used a sherbert lid)
You will need:
pencil
string
glue
box cutter
scissors
STEP 1: Trace a Circle
Use your circle pattern to trace a circle, centering as best you can.
STEP 2: Draw the Petals and Cut It Out
Draw petals around the circle, and cut away the excess with the scissors.
I found it easier to cut all the petals on one side first, then the other.
You might be left with some little tufts in the corners; either pick them out or cut them away carefully.
My sunflower came out a bit short on the sides because my cardboard wasn't quite big enough. Make sure yours is big enough if you don't want this to happen!
STEP 3: Cut Out the Center
After some farting around, it seemed like boxcutters were the way to go to cut the inside out. Be extremely careful with this; the blade is razor sharp. If you are very young you might want to get help with this step.
To make a cut, first just score along the circle; don't try and go all at once. Just keep making progressively deeper passes, and don't get into a hurry. Also you will want some kind of tough/expendable surface to cut on.
If you end up with rough bits from the cut, take the cutter and CAREFULLY trim them off, like you are whittling wood.
At this point, you could find an angle that it hangs nicely from, and make a hole at the hang point.
STEP 4: Paint Your Flower
Now flip it over, because you've got gnarly pencil marks on that side.
Give your flower several coats of paint, and plenty of drying time between each coat. Because i started off with bare cardboard, it took me quite a few coats to get the color i wanted without the brown cardboard showing through. If you were to give it a base coat in white it probably would take less.
To keep your petals looking neat and semi-realistic, make sure to stroke from the outside towards the inside of the circle each time; dont just slop it on in any direction. Don't forget to give the back a coat or two!
Because i only had yellow paint in acrylics, i used some watercolors to create some shadows and keep it from looking too flat.
Once all your paint has dried, outline your petals in sharpie. (i used brown because i thought it looked nicer.)
STEP 5: Add the Backing
Now flip it over again.
Take enough screen or felt to cover the hole with some overlap, and trim it so that none shows over the edge of the petals.
Put the screen to the side, and lay down a line of glue around the hole. Don't get right up on it, leave a small space.
Put the screen down over the hole, and take your finger and spread the glue away from the hole. As you work, make sure the screen stays taut over the the gap. Pull it to the edge if its getting too wrinkly.
At this point, you could take another piece of cardboard, cut a slightly larger hole out of it, and trim the outer bit so that it doesnt show over the petals. Lay that down over the screen in the back and let dry. I was too lazy to do this, but it would help keep the screen in place.
STEP 6: Admire!
String your string through the hole, put some earrings in, and enjoy your creative and functional work of art.
2 Comments
IVT 11 years ago
ChrysN 15 years ago
