Super Cheap and Easy Fog Chiller
Intro: Super Cheap and Easy Fog Chiller
A fog chiller cools down fog from a fog machine so that it stays low to the ground. This one costs around $5-$10. I had everything I needed already, you probably do also.
STEP 1: Materials
There is not much that you need for this project.
MATERIALS
1. Foam cooler
2. Dryer hose
3. fog machine
4. Ice
TOOLS
1. compass
2. knife
MATERIALS
1. Foam cooler
2. Dryer hose
3. fog machine
4. Ice
TOOLS
1. compass
2. knife
STEP 2: Measure
You need to cut a hole in both sides of the cooler for the dryer hose, so:
set your compass to 6.5 cm and draw two circles, on opposite sides of the cooler (longways)
STEP 3: Cut
Cut out the circles you just drew, the cooler should now look like this
STEP 4: Feed
Feed the dryer hose through the two holes. leave one end longer that the other. one side should have about 4 in coming out, the other about 10. try bending the hose inside the cooler to get the most contact with ice.
STEP 5: Ice
Fill the cooler with ice
STEP 6: Attach
Attach The cooler to your fog machine by pushing the longer end of hose around the nozzle of the fog machine. just keep the two together and all of the fog will go into the hose.
STEP 7: Fog!
turn on the fog machine and enjoy your fog not floating away!
103 Comments
psychodj 7 years ago
I made it, didn't really work. How long should the tube 'chill'? I let it chill for two hours then tried it with two different fog machines got the same results: a room full of smoke. No low-lying 'fog'. I think it's time to go back to dry ice.
dag4415 11 years ago
JennyJ23 7 years ago
I love this comment and I completely relate.
AndyH31 7 years ago
Awesome. Simple but very effective!!!
jasongroupindustries 11 years ago
CaseFace5 11 years ago
Aron313 12 years ago
butterninja 12 years ago
lolligag 12 years ago
Shadetree Engineer 16 years ago
Trivial27 14 years ago
CodeKid1001 12 years ago
Trivial27 12 years ago
Anyways, if it helps what I used was a Sunterra Mistmaker Fogger http://www.sunterrausa.com/decorative-accessories/product/300409 that I picked up at Menards. It seems they have something similar listed on their website now. http://www.menards.com/main/p-1657811-c-10121.htm (the LED setup is different).
The first time I tried combining the jack-o-lanter, the pond pump, and the mister I put it in the "catch pond". It wasn't bad but well... you can guess how much better it looked with the fog mister inside the pumpkin...
powdermnky007 14 years ago
allenh 16 years ago
Longtimer 13 years ago
cowsrock87 14 years ago
T3Hprogrammer 16 years ago
