Introduction: Super Easy Easter Marshmallow Bark
See more super easy, family friendly recipes on my blog, www.ButterWithASideofBread.com
I have a confession to make: while most people change a recipe to make it skinny, I took a healthy recipe and went the other direction. Ha! You know, as in, less skinny. Sorry! I know, I know, I'm awful. At any rate, the original WW recipe was a such a good idea and to be honest I really don't think my changes added an obscene amount of calories. Maybe just a few. They're so cute though, aren't' they!?
I used a metal cookie cutter to make them Easter egg shaped- you can use another metal cutter for a different shape, or simply cut them into squares, like I've shown below. I took these to a family dinner, thinking the kids would love them. Little did I realize how much the adults would love them too! They were a huge hit!
Step 1: Ingredients
- 1 bag white chocolate chips {12 oz}
- 3 cups mini rainbow marshmallows
- about 1 TBSP shortening {optional, but it really makes the melting process easier!}
- Easter sprinkles or other fun sprinkles for decor on top!
Step 2: Melt the Chocolate
Measure out 3 cups of marshmallows. Line an 8x11 glass dish or a half-sized cookie sheet {like I used!} with parchment paper.
Put white chocolate and shortening in a medium sized glass bowl.
Melt chocolate in the microwave for 1 minute. Give it a small stir, then return to the microwave in 30 second increments, until chocolate melts completely when you stir it.
HINTS FOR MELTING WHITE CHOCOLATE: My bowl of chocolate took 2 minutes in the microwave. White chocolate looks like it's not all melted when in fact it really is. Stir it several times and make sure it really needs more microwave time before jumping the gun and just giving it more time. I usually have to stir mine for a good 30 seconds until it's really fully melted.Melting white chocolate can be a little frustrating if you've never done it before. The reason is because white chocolate seizes easily. When chocolate seizes it actually looks like it's not melted yet, which prompts people to return it to the microwave, which makes the whole thing worse. Stir several times after each 30-second increment in the microwave. Many times you'll find that a good 20-30 seconds of stirring it around in the warm bowl will melt it the rest of the way! If you've had back luck with melting chocolate in the past, try adding shortening!
Step 3: Add Marshmallows to Melted Chocolate
After chocolate is melted, add marshmallows and stir to coat. You'll want to do this kind of quickly- be sure the chocolate coats the marshmallows well, but if you take too long the marshmallows start to melt, which you don't want.
Step 4: Transfer to the Pan
Transfer chocolatey marshmallows to your prepared pan. Using a rubber scraper, make sure marshmallows extend to the edge of the pan. Press down slightly to make it all somewhat even. Shake on any sprinkles you'd like to decorate the bark with.
Put in the freezer for about 20 minutes, until chocolate is set. You want to use the freezer so that it cools the mixture as quickly as possible- you don't want those marshmallows to melt!
Step 5: Cut Into Shapes & ENJOY!
Remove from the freezer and let sit on the counter to return to room temperature. Cut into pieces. If you use a cookie cutter, I suggest using a metal one and spraying the edges with cooking spray prior to cutting.
11 Comments
5 years ago on Introduction
These look great but how long do they take to prepare?
5 years ago on Step 5
Oh my god. I need this.
6 years ago on Introduction
definitely making this for our Relay for Life Easter Bake Sale
7 years ago on Introduction
I'm pretty sure white baking chips aren't real chocolate. http://www.cooksillustrated.com/taste_tests/482-wh...
That said, I'm still going to wrestle with some white candy melts and make this! Excellent Ible… thanks for sharing!
7 years ago
Forgot to say - love the multi coloured ones for Easter!
7 years ago
I made these with just white marshmallows & silvery sprinkles for Christmas trees. If you use gluten free marshmallows cute present for coeliacs. & goes down a treat with adults too!
They look super cute and delicious!
7 years ago
Wow!!! I want to make these today!
How cool! And very, very pretty!
Yummers!
These are absolutely beautiful!
