Super Easy Paper Flowers for $2!
Intro: Super Easy Paper Flowers for $2!
I learned this flower-making method from an annual Japanese bazaar that I help out at. It's taught at an origami stand held for little kids to learn origami, so this is a super easy way to get started!
These flowers are super quick, super cheap, and super awesome!
STEP 1: Materials
- Post-its or square pieces of paper (Note: each flower will take one and a half pieces of square paper to make.)
- Wire, pipe cleaners, etc. (I used galvanized wire from the dollar store)
- Scissors
- Pliers (if you're using pipe cleaners, you don't need them)
STEP 2: Folding the Petals
- Cut the square in half.
- Fold the square in half, length-wise.
- Fold the corners down, making two triangles.
- Bring top down.
- Repeat on other side.
You've finished two petals! We'll call these "pieces". Each side of the piece is a petal of the flower. You will need a total of three pieces to complete a flower. So, fold two more pieces.
When folding, make sure the side with the color you want to show is on the inside. In the case of Post-its, this means that the sticky side should be on the outside. Your folds will cover any unwanted colors/stickiness.
Make sure your creases are crisp and clean. Uneven folds will lead to ugly petal edges and may cause your flower to look lopsided.
STEP 3: Putting the Flower Together
- Stack three of the pieces together, side-by-side.
- Take your wire/pipe cleaner and place it on top of the stack.
- Bend the piece of wire back and twist the excess.
Do not twist the wire too tightly or too loosely. If they are not secure, the petals will fall out or move around. If the wire is too tight, it can easily cut through the paper and ruin the flower. So you'll want to make a snug (but not tight) fit on the wire.
Once it's all put together, you can trim the wire. I chose 8 inches for my stem length, but you can pick whatever length you like.
Now you can proceed to shaping the petals!
STEP 4: Shaping the Petals
- Take your thumb and index finger.
- Pinch the petal. Use your thumb to shape the ends.
- Repeat five more times.
And you're done!
39 Comments
ninjacow258 13 years ago
LadyInRedwoods 13 years ago
krysteanuh 13 years ago
peterbryenton 13 years ago
pop88 13 years ago
smilgy 13 years ago
loriphillips1 9 years ago
Just made these with my son and he would like to use the idea as a 4-H project. Can he teach others to make these as a working exhibit and site you for the copyright?
krysteanuh 9 years ago
emmasharkeyshark 10 years ago
mugdham 10 years ago
rinkle_sheth25 12 years ago
drummgurl 12 years ago
monseulementreveur 12 years ago
gewalop 12 years ago
Eli44 13 years ago
barley123 13 years ago
icelandinthesun 13 years ago
Thank you so much for sharing, with the pictures the steps were super easy to follow.
Thank you so much! Hope your kindergarteners have fun :)
