Super Effects With LED Strip and LED Circuit
Intro: Super Effects With LED Strip and LED Circuit
Hii friend,
Today I am going to make a circuit of super effects light with LED Strip and LED.
Let's get started,
STEP 1: Take All Components As Shown Below
Components required -
(1.) IC - LM555 x1
(2.) LED Strip
(3.) LED - 3V x1
(4.) Resistor - 330 ohm x1
(5.) Resistor - 220 ohm x1
(6.) Capacitor - 25V 220uf x1
(7.) Power supply - 12V DC
(8.) Battery - 9V x1
(9.) Battery clipper
STEP 2: Short Pin-2 to Pin-6
Firstly we have to short the pins of ic.
Connect pin-2 to pin-6 of the IC as solder in the picture.
STEP 3: Again Short Pin-4 to Pin-8
Next we have to solder pin-4 to pin-8 of the IC as you can see in the picture.
STEP 4: Connect 330 Ohm Resistor
Next connect 330 ohm resistor between pin-7 to pin-8 of the IC as you can see in the picture.
STEP 5: Connect 220 Ohm Resistor
Solder 220 ohm resistor between pin-6 to pin-7 of the IC.
STEP 6: Connect Capacitor
Next we have to connect 220uf electrolytic capacitor to the circuit.
>> Solder +ve pin of capacitor to pin-2 of the IC and
solder -ve pin of capacitor to pin-1 of the ic as you can see in the picture.
STEP 7: Connect LED to Circuit
Next solder +ve leg of LED to pin-4 of the IC and
solder -ve leg of LED to pin-3 of the IC as you can see in the picture.
STEP 8: Connect Battery Clipper
Solder +ve wire of battery clipper to pin-8 of the IC and
Solder -ve wire of Battery clipper to pin-1 of the IC as solder in the picture.
STEP 9: Connect Battery
Now connect battery to battery clipper and the result will occur LED is blinking.
NOTE : We can connect LED Strip instead of LED but LED Strip should be of 4-5V then LED Strip will glow with super effects.
STEP 10: Connect LED Strip Instead of LED
Next Connect LED Strip to the circuit instead of LED.(Polarity of LED Strip will be same as LED)
STEP 11: Connect 12V DC Power Supply
If LED Strip is not glowing with 9V Battery then connect 12V DC power supply to the circuit and now LED Strip will give super effects,
But with 12V power supply this circuit can't access for long time.After some time IC will be dead.So use this circuit with 9V DC.
Thank you
