Super Mario Bros. LED Mushroom Halloween Pumpkin!
Intro: Super Mario Bros. LED Mushroom Halloween Pumpkin!
How to create your own Super Mario Brothers 1-up LED powered Pumpkin! A great change from your standard, boring Jack-o-Lantern. Brilliant idea eh?
More Hacks, Mods, and DIY Projects at HacknMod.com
Get dirt cheap LEDs and DIY project supplies at the HacknMod Store.
STEP 1: Prep the Pumpkin!
Cut the top of the pumpkin, gut it out, print out the design, tape it on the pumpkin, poke holes to out line the design. YOU KNOW THE DRILL!! :)
STEP 2: Cut Out Your Mushroom!
Using your standard mushroom carving knife, cut out your pattern. It's recommended you place foil at the bottom of the pumpkin and under the top of the lid to reflect light and thoroughly illuminate your design. Be sure to insulate your leds if you place them at the bottom to prevent them from shorting out.
STEP 3: Prep the LEDs
To increase the spread of light throughout the pumpkin, I sprayed each led with glass frosting spray paint. If you don't want to drive to Home Depot and spend $4 on that, you can always sand them with low grit sand paper (wear eye protection, i've heard of them exploding before)
STEP 4: Solder the LEDs!
I used 5 leds in each red, green, and blue. They are all 5,000 or 6,000 mcd (brightness). I then soldered them together and hooked them up to two 9 volt batteries. Only the red LEDs needed a lot of resistance (they are only 2v). Then, be sure to insulate the wires before getting them near aluminum foil.
STEP 5: Finish It Up!
Put foil in the bottom of the pumpkin. Put the leds inside. (if you want you can place a toggle switch on the outside of the pumpkin) Then, put it on your front porch and show off your Super Mario Pride!
Watch the video for '''''More Details & Goodies!'''''
Be sure to Visit My Website - www.HackNMod.com - Thanks!
29 Comments
gdene 12 years ago
MrStuff 16 years ago
ldupalco 12 years ago
But it'll do :)
Thorolf 15 years ago
Joe426 16 years ago
Joe426 16 years ago
nitrodude150 13 years ago
http://dl.dropbox.com/u/3237444/Mario_Stencil.eps
and-reas 14 years ago
Arbitror 14 years ago
noobie605 14 years ago
SessiZ 16 years ago
Sac Bakımı
Derin 14 years ago
Kankuro 15 years ago
ThinkBeforeYouSpeak 15 years ago
dannosliwcd 16 years ago
Joe426 16 years ago
Shifrin 16 years ago
oinkoinkzoopals 16 years ago
calikoala 16 years ago
