Super Nightvision Headset Hack!
Intro: Super Nightvision Headset Hack!
We have all seen the webcam nightvision hacks and other ways to make nightvision cameras but this will blow you away! This a Super Bright Nightvision Headset that lets you walk around in total darkness AND record what you see! My inspiration for this project came from Brad Graham & Kathy McGowan Watch the video and see the Test Results and then build your own! I hope you enjoy this Instructable as much as I enjoyed making it!
Get the Infrared LED's for this Project HERE
STEP 1: What You Need...
Dig through your closet or ask a friend if they still have a classic full-size VHS camcorder hanging around collecting dust. Or go to garage sale or pawn shop and find one for cheap. All we need is the analog viewfinder
STEP 2: You Will Also Need...
1. Twelve 10mm, 200mw triple Infrared LED's. These babies are mean! They each have 3 LED's in them and are very powerful! You can get the LED's HERE
2. A project box/enclosure from Radio Shack or any other larger size project box. This one is 5" X 2 1/2" X 2".
3. A red or any other color LED to be used for a power indicator
4. A shielded, panel mount Phono Jack
5. A SPST switch
6. (2) 10ohm resistors
7. A Super Low Lux Mini B&W spy camera that can be powered by 9 volts
8. 9 Volt batteries
5. A SPST switch
8. 9 Volt batteries
STEP 3: Disassemble the Viewfinder
Remove the viewfinder from the camcorder. Depending on the camcorder, this may be as easy as unplugging the connector to the camera and removing the viewfinder screws to release the entire unit. Some may be hard-wired inside the camcorder which will require more work. Once removed, take off the plastic housing to reveal the viewfinder components. Identify the ground wire. To identify the power wire, you will have to do some tracing back to a power regulator or diode. You can use an adjustable power supply (recommended) or 9 volt battery to test the viewfinder power line. After identifying the ground and power, the video libe can be located byfeeding a video signal into the other wires.
STEP 4: Build the LED Array...
I used 12 LED's. 6 LED's wired in series to another series of 6 in parallel. Attach the 10ohm resistors to the positive end of the array.
STEP 5: Prep the Housing...
Now it is time to drill all of the holes in the project box. I drilled 12 holes for the LED array. A large hole (using a hole saw) for the viewfinder, 3 holes for the switch, power indicator LED and phono jack.
STEP 6: Install All of the Components...
Time to install all of the components and wire according to the schematic. Be sure to test each compnent along the way. Basically all grounds go to and out of the switch. The LED array, micro camera and power LED are powered by one 9 volt battery and the viewfinder is powered by another.
STEP 7: Close It All Up and Test It Out!
You will be amazed at the brightness of these LED's in perfectly dark environment. With the right low-lux camera you can see in complete darkness since the infrared LED's generate light at a frequency that the camera can see. And, you can record what you see by taking the video out to a camcorder! Stealth at it's finest!
392 Comments
_Blamoo 8 years ago
I have the same viewfinder as yours, can you give me some tips on wiring it?
DiegoR4 9 years ago
hey kip! i was wondering, could i get the viewfinder somewhere else (a disposable camera maybe), since i highly doubt that my dad will let me take apart any of his... Or maybe you could make this one of your kits as well?
hapak 9 years ago
With so much of digital cameras around all you have to do is find a repair shop for video cameras. They would have numerous junk cameras lying around and would be happy to remove a viewfinder and sell it to you cheap. I am in New Delhi (India) and got my viewfinder for about $4 equivalent. It works but I am yet to progress the project. Presently I am assembling the IR light. Got a 100 LEDs.
rashish.vaibhaw.5 9 years ago
WHERE TO BUY CONGO BLUE AND PRIMARY RED GEL SHEETS IN INDIA? PLEASE EMAIL ME IF YOU KNOW..... rashishvaibhaw@gmail.com please tell me if you know, GOD will bless you!
chaz_p 14 years ago
and wanted to know if it was usable to create a diy thermal imager, so ive come to you to show me how :D
mluong1 10 years ago
natsud1 11 years ago
Suraj Grewal 10 years ago
malkav2024 11 years ago
I just read your message regarding the viewfinder rewiring. I currently have the same problem : I found the proper ground and + wires to power up the viewfinder, but I have a very poor image quality when I hook up the video signal (I get an partial picture shaped like a horizontal line that drops in and out of the screen). Did you get the same problem ?
I will try to add a capacitor to see if its sorts things out. What kind of capacitor did you use exactly ? I am very surprised that any kind of capacitor can fix the problem. I also don't know how a capacitor can, electronicaly speaking, fix a video signal. Maybe you have an opinion about that ?
Thanks in advance !
Actually, my setup didn’t worked because I forgot to hook up the video ground cable ^_^;
I managed to decode 2 viewfinders so far. For the record, I also had the case where the viewfinder had 2 video cables. None works if you hook one of them with a video signal. You have to join the 2 cables together then hook it up with a video signal.
Cheers
Yard Sale Dale 10 years ago
Kzummo 10 years ago
Jimmy_retro 11 years ago
abgersaurus 12 years ago
a have a viewfinder with 4 yellow wires and 1 black wire. how do i find out which one is video and power?
T_T_ 11 years ago
abgersaurus 11 years ago
