Introduction: Super Easy Galaxy Planetarium
May be you have seen home planetarium but the one showing galaxy like are rare ( I haven't seen one yet myself). So I decided to make this super easy-dirt cheap galaxy planetarium. Head on and you will be having your own in less than 5 minutes.
Step 1: Materials Required
You will need:
1 Plastic Glass
Aluminium Foil
1 thin needle ( you can use anything which is pointed and has more thickness than the needle)
1 medium thickness nail
1 flashlight (mine was Blue LED based. I don't know whether ordinary bulb flashlight will work or not since for "Diffraction" and "Interference" to take place(on which my planetarium is based) you need a monochromatic light .Simply just use a LED flashlight.
Sticking Tape(optional)
Step 2: Assembly
All you have to do is just wrap the foil on the outer side of the glass( take care that the foil doesn't tear at any place). Do not wrap the foil in the interior(well you can but I didn't tried that, so do your own experimenting).
Now make holes by needle on the foil covered glass. Then make holes using the nail. You can refer to pictures.
Step 3: How to Use
Place the flashlight below the glass as shown on the picture. If the flashlight is larger than the cup's circumference then you have to cover the extra leaking light with electrician's tape. Now switch on the flashlight, switch off the room lights and project the image on a wall and enjoy your galactic ride.
Try with different pattern of holes and every time a new galaxy will be born.
How it works:
It works on diffraction mainly which is distortion due to very small slits and holes which is due to the wave nature of light. Also the rough and reflective edges of aluminium foil also helps in reflecting and distorting the light creating a galaxy like pattern.
Check out other exiting experiments on http://scimad.com/
9 Comments
7 years ago
How did you get that incredible whorl in the centre?
11 years ago on Introduction
Could be really cool if you print out a nice detailed diagram of constellations, then overlay the foil and use it as a template to make an accurate night sky.
Great results with this idea manish15.
12 years ago on Introduction
its nice from india akash
Reply 12 years ago on Introduction
Thanks
To help with unwanted light caused by relfections inside the foil coated cup, you could paint the inside of the foil black with spray paint, might help clean up any non-stars on the ceiling.
yes very helpful when you want to create precise constellations.Thanks.
13 years ago on Introduction
Did you put any design or reproduction in this, or is the pattern creative / random?
L
Reply 13 years ago on Introduction
Its totally random, you don't know what you will get! However you may try some pattern of your own by experimenting.
Thanks.
L
