Super Long Ranged Sniper
Intro: Super Long Ranged Sniper
Keep out the Pesky rodents from eating your Veges by shooting darts through them ! Or put a marshmellow in it and shoot your little brother! Do not shoot darts at anyone or anything you dont attend on killing or serverly hurting!! '
DISCLAIMER: MAKE NO MISTAKE, THIS IS A WEAPON. DO NOT SHOOT AT ANYTHING FRAGIAL OR ANYONE. IF ANY PROBLEM OR DESTRUCTION IS CAUSED BY THIS, I CLAIM NO RESPONSIBILITY.''
STEP 1: LETS GET STARTED !
What you need:'
4ft. of 1/2in. PVC( you will have extras)
2 1/2in. Tees
1 1/2in. Flat Cap
1 1/2in. round cap
1 1/2in. Ball Valve
1 1/2in. Elbows
1 Maxi lock string holder that can fit over male 1/2in. PVC (optional)
Scope or whatever you what to use as a sight! (optional)
2L Coke Bottle
PVC Cement
Drill and bit
Little Marshmellows (optional)
PVC Cutter
Ball Pump and Adapter used to inflate air mattresses (make sure it fits in a ball pump) '
Cut the PVC into these measurements!'
A= 23in.
B= 2.5in.
C= 2.5in.
D= 5.5in.
E= 3in.
F= 4in.
G= 2.5in.'
2 1/2in. Tees
1 1/2in. Flat Cap
1 1/2in. round cap
1 1/2in. Ball Valve
1 1/2in. Elbows
2L Coke Bottle
PVC Cement
Drill and bit
PVC Cutter
A= 23in.
B= 2.5in.
C= 2.5in.
D= 5.5in.
E= 3in.
F= 4in.
G= 2.5in.'
STEP 2: Drilling the Hole!
TAKE the drill and drill a hole in the flat cap! Make the hole big enough but small enough to put the adapter in tightly !
Put glue on the inside of the Flat cap and let it dry !
Make sure it doesn't move in side..... then put glue on the outside of the cap !
Make sure it has no holes left!! '
STEP 3: Put the Scope on !
Time to put the scope on ! This is completely optional! I use a Daisy Air Rifle Scope! They are about $8 at Wal-Mart.... !
Well its time to put it on to put it on take two scrap PVC peices that are the same size ! glue the Scraps to the barrel and let it dry ! After it drys glue the scope to the scraps !! And let it Dry!!
IF your having trouble understanding what im saying, look at the PICS!'
STEP 4: Make the Tank!
NOW lets put the tank together!
First lets start with the BALL VALVE ...... its connected to Peice (B) !
Peice (B) is connected to the (Tee)!
Lets go to the (Tee)'s bottom open slot where (C) goes in ..... and the (flat cap) with the adapter
connected in it!!
There should be one more slot open where Peice (D) goes!
The elbow connects to Peice (D)! IN the othe open slot put peice (E) in there!
YOU should have another (TEE) left and connect it to Peice (E) on the bottom peice that doesnt have have another open slots like that!
Put Peice (F) on the left slot and put the cap on it !
Heres the last step..... put Peice (G) in the last hole on the (TEE) ...... and put the COKE BOTTLE over peice (G) then Glue it!!
THERE YOU HAVE IT !! THE TANK IS DONE!!!!'
connected in it!!
STEP 5: PUT the Rest on !
Now you should have the Ball Valve and the Barrel left! !
Put the Ball Valve and Connect it to the barrel! (DO not GLUE this is the single most expensive piece you HAVE TO BUYand once you glue it on tightly you cant get it off! )
Now you have the Valve and the Barrel Connected!
Now connect the Barrel and valve to the tank ! i would recemend you not glue the tank to the Ball Valve! i would just use strong tape to hold it in place!!
STEP 6: ADD FINISHING TOUCHES!
NOW its time to add Kool Things to it like The bipod and suppressor!!
FIrst lets talk bout the BIPOD!
NOw Find To long Peices OF PVC and cut them the same size! (if you dont have extra PVC find something else or you dont have tho make a bipod!
Now glue the to legs wereever you want them !
there you have it a bipod!'
STEP 7: LETS ADD THE SUPPRESSOR!
NO ITS TIME TO ADD THE SUPPRESSOR!
i used a MAXI-LOCK sewing string holder!
you can use anything that looks kool and fits!!!
Now to put it on slide the end on till it fits snug and then glue it and there you have it you super air rifle!!
STEP 8: NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
ok i gues you get it lol! shoot whatever ammunition you want!!! TELL ME HOW YOU LIKED THIS INTRUCTABLE !!!! IF YOU HAVE ANY QUESTIONS ASK ME THEM ! IF YOU THINK THERE IS SOMETHING I MISSED TELL ME AND I WILL TRY TO FIX IT!!'
!!!!!!!!!!!!!!!!!!!!!!!!!ENJOY!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
142 Comments
saskae 10 years ago
how long dose the barle have to be
boredom99 12 years ago
brechtooms 10 years ago
But you could also make your own air container from a bigger pvc pipe.
ericquins 13 years ago
bcavaciuti 10 years ago
Aron313 12 years ago
sandmman 12 years ago
samdaman 14 years ago
TheAirSpecialist 16 years ago
receiver545 16 years ago
TheAirSpecialist 15 years ago
Here's the low down:
VERY HIGH PRESSURE AIR CANNON
Operating Pressure:6000psi-10000psi
Velocity: approx 2850 f/s take or lose some
Cal: .50BMG
Rifled: 8 groove sharp cut
Operating temp: 40oC-120oC
Recoil: alot!
Firing Sound: large crack and bang, followed by the sound of the sound barrier being broken
Damage: killed a large wild pig at 500m, leaving extremely large exit wound
Accuracy: 100m vairence of 4cm either way
The 1st time me and my friend fired this (after 2months of finding parts, turning barrels and chambers, heat problems and SCROUNGING FOR MONEY!!)
we had it mounted on a piece of thick hard wood and steel pegs, pegging it to the ground it broke its mount and half deafened us which was a hell of a fright, especially having 4 full hours of constant ringing in your ears. It snapped The main bracket closet to the muzzle and bent the bullet locking rod which is a thin piece of stainless steel which pokes at the rear of the bullet to hold it in place (very hard steel 2 bend btw). we fired it at this tank of water which just dissapeared at a cloud of mist (look SOOO cool).
A week later me and my friend took it to my fathers farm and found a big big and shot it at about 500m and it dropped like it wasn't even alive, it had blood coming out every opening of its body and a exit wound of about 2 fist sizes and didn't look to good.
The barrel is one meter long and is 1.5inches think of bizzleite (real heavy)
Landon Sullivan 15 years ago
WarPig137 15 years ago
bendog38 14 years ago
