Surround Sound From 3.5 Mm Stereo
Intro: Surround Sound From 3.5 Mm Stereo
This Instructable describes how I built a surround sound system for use with a 3.5 mm stereo output. The goal is to extend surround sound experience from any 3.5 mm stereo headphone output with quality and simplicity. Works great with PCs, MP3 players, CD players, tape recorders etc. This is a low power (around 1 Watt) version of the ABC surround sound decoder.
You will need the following items to build 3.5 mm surround sound:
- Parts shown on attached schematic.
- Plugboard.
- 4 heatsinks (1.5" x 2" copper or aluminum sheet metal).
- 4 speakers (4 - 8 Ohm, about 3 Watt nominal power). Almost any type of speaker works:
Computer speakers, satellite speakers, small speakers, big speakers, etc.
- Wire.
- 4 phillips 6-32X1/4 nylon machine screws.
- 4 nylon 6-32 hex nuts.
- Heatsink grease.
- 12V, 500mA or more power supply.
- 3.5 mm plug to 3.5 mm plug cable.
Drill, solder gun and soldering accessories, cutters, tweezers, wirestripper.
- Plugboard.
- Wire.
- Heatsink grease.
STEP 1: Making the Circuit
The circuit I used consists of a power amplifier with 3.5 mm jack input and the surround sound decoder. 3.5 mm input jack can be replaced by cable with 3.5 mm plug if desired.
Mark future hole center by placing T3 transistor at lower left corner of the heatsink. Drill hole in each heatsink.
Assemble circuit shown on schematic. This step requires some assembling and testing skills.
Apply a small amount of heatsink grease on T3, T4, T7, T8 transistors and secure heatsink on each of them using screw and nut. Warning: heatsinks should not touch each other!
STEP 2: Speaker Preparation
I used pair of low power Phillips speakers available at Walgreens and pair of old PC speakers.
Attach wires to each speaker paying attention on polarity.
STEP 3: Final Connection
Any 12V, 500mA power supply is sutable for this application.
Connect power supply and speakers to circuitry - system is ready.
20 Comments
Chunky240 6 years ago
An active version with centre and sub outs can be found here, look for projects 18 & 26.
https://www.sound-au.com/projects-0.htm
And here-
https://www.instructables.com/Surround-sound-for-free-it-could-save-your-marria/
jaxboy 11 years ago
DustySeven7 12 years ago
i-blaze 12 years ago
Rahul16 13 years ago
wobbler 13 years ago
HADJISTYLLIS 14 years ago
RRC 13 years ago
HADJISTYLLIS 13 years ago
Marble of Doom 13 years ago
RRC 13 years ago
tigerdog330 14 years ago
RRC 14 years ago
SRChiP 14 years ago
RRC 14 years ago
SRChiP 14 years ago
RRC 14 years ago
SRChiP 14 years ago
RRC 15 years ago
