Introduction: Survival Wooden Knife
Cool survival wooden knife made in only 15 minutes
Step 1: Things You Will Need:
Step 2: Cut the Wood
You can decide how much to cut according to how long you want the blade to be.
Step 3: Sharpen and Sand
Step 4: Adjusting the Width
Adjust the width of the bottom of the blade according to the hole in the bamboo.
Step 5: Connect, Glue and String
Connect to the bamboo, adding glue to reinforce it and tie string around it as tight as you can.
Step 6: It Should Look Like This.
Feel free to customize it and comment about them. Stay safe.
Outside Contest 2016
DIY Summer Camp Challenge
13 Comments
7 years ago
Nice job! It's nice that it is so easy to sharpen if it gets dull :)
7 years ago
Wait so you need a regular knife to make a wooden one though :p
Reply 7 years ago
But the small pocket knife won't kill an animal easily because it isn't long enough;)
Reply 7 years ago
Unless you attach it to a stick to make a spear !
Reply 7 years ago
well then if you are surviving with someone else u could give him this wooden one and you keep the other metal pocket knife to yourself or this could just be a secondary knife just in case u loose the pocket knife or even brake it.
7 years ago
I cant imagine this holds an edge very well? But then again, Its easy to sharpen
Reply 7 years ago
Forgot to say, Well made. I'd rather have this than nothing if I was stranded and needed a tool/weapon
Reply 7 years ago
Good luck finding glue in the wild... trying to "survive" and all...
Reply 7 years ago
have you ever heard of wax in the forest it's quiet easy to found
Reply 7 years ago
Actually, I've made some pretty awesome glue from tree sap! Glue is probably one of the easiest substances to obtain without basic tools.
Thanks for wishing all of us good luck though!
Reply 7 years ago
Glue is there to reinforce so you don't need to follow that step, because if the bamboo and stick fit tightly you won't have problems.
7 years ago
Hey, if you run into a rude and inconsiderate Vampire while lost in the woods you will be fixed up to deal with it. Pointy sticks are an old school way to protect yourself from a lot of critters. Nice job.
7 years ago
Well done. dan3008, if you fire harden the blade, it hold an edge surprisingly well (depending on the type of wood of course).
