Sweethearts Candy Lightbox W/ Color Lithophane
Intro: Sweethearts Candy Lightbox W/ Color Lithophane
Been awhile Instructables! How've you been? When was the last time we talked?! Looks like almost a year ago with Retirment Clock? Wow, 2023 was BUSY!
Anyhoo, with Valentines Day approaching, this seemed like a good excuse to screw around with "explore the capabilities" of the newish 3D printer!
So here’s my take on the classic Valentines favorite, Sweethearts candy! Now with 100% less chalk taste! 🤣
This lightbox is modeled after the Sweethearts candy box design from the 90’s. I like the look of it for a light box, and the clear “heart window” in the middle of the box gave me an idea - What if we put a color lithophane of your “Sweetheart” here?!
So I took that “what if” and added some googling, some Fusion 360-ing, some trial and error with 3D printer shnozzle sizes and light diffusers, and voila. I present to you the Sweethearts Candy Full Color Lithophane Lightbox! That’s kind of a long title isn’t it…
Regardless of the long title, I’m really happy with how it turned out and wanted to share it!
OK, enough chit-chat, here’s how to make the thing -
STEP 1: Lightbox Instruct-do-mundos
The file for lightbox facia is setup to print the heart diffuser for the lithophane at the same time.
Print Sweethearts lightbox with the .2 mm nozzle using the pink, red and white filament. Orient it with the color side on the bed. I like using a textured bed, it helps hide any layer lines. No supports are needed.
- Nozzle size - .2 mm
- Nozzle temp - 220*C
- Bed surface - Textured
- Bed temp - 55*C
- Layer height - .1 mm first layer, .12 mm after
- Walls - 3
- Infill - 100%, rectilinear
- Speed - SLOW! 20mm/s first layer, and under 60mm/s for the rest. .2 mm nozzle does not like to print fast.
- Support - No
I tried to keep it printable with a .4 mm nozzle, but I couldn’t get the text to print right and there were pinholes.
STEP 2: CMYK Full Color Lithophane Printing
Create your color lithophane using this lithophane generator https://lithophanemaker.com/Color%20Lithophane.html
Make it 65mm x 65mm square. My exact settings are in the pictures attached to this step.
Use the Negative Lithophane Heart file to cut out your heart when you slice it. (I was not able to find a better way to make a heart shaped full color lithophane.)
Print with CMYK filament, the .2 mm nozzle will give you more detail, but if you haven’t installed it yet the .4mm will typically give acceptable results. I printed this lithophane with a .4 mm nozzle while I was waiting for the .2 mm to show up. Yes, it might generate a non-manifold edge waring, I found this was pretty common, repairing it didn't seem to affect anything in the finished product in this instance.
- Nozzle size - .4 mm
- Bed temp - 55*C
- Layer height - .2 mm first layer, .1 mm after
- Walls - 2
- Speed - 35mm/s first layer, other layers should be whatever speed still gives you good PLA prints.
- Support - No
I'm totally fascinated with the fact this works so well! I had no idea this existed until I upgraded to a new 3D printer. Here is the link to the guide I used to get started with color lithophane printing if you’d like to read it https://wiki.bambulab.com/en/knowledge-sharing/CMYK-color-lithophane-printing-instructions%20
STEP 3: Frame Printing
Print the Bambu CMYK Lithophane frame. STL file is available here https://wiki.bambulab.com/knowledge-sharing/cmyk-color-lithophane/cmyk_frame_final_v2.stl
Light will bleed through the frame if you use white (ask me how I know...), so use a darker color if you can. The magenta from the CMYK pack works well. Remove the supports from the print when finished.
Do not print the light guide plate.
- Bed temp - 55*C
- Layer height - .2 mm for all
- Walls - 5 (to block light, not for strength)
- Infill - 33% gyroid or your favorite flavor
- Support - Yes, Tree - organic worked well for me. Also enable brim.
STEP 4: Assembly
Slide the LED backlight board into the back slot of the CMYK lithophane frame.
Put your color lithophane heart into the back of the Sweethearts lightbox. Snap the heart diffuser onto the back to keep it in place and diffuse the LED lights.
Gently snap your finished Sweethearts Lightbox Lithophane into the front of the CMYK lithophane frame.
(Note: The middle slot in the frame where the light guide plate would go is not used in this design. The light guide/diffuser is integrated into the back of the lightbox print.)
Plug in your USB C cord and light it up!
STEP 5: Thought Candy
OMG - LOOK AT IT!!! Can you believe this is 3D printed? I'm impressed.
As you can see I picked my doggo as my sweetheart this year! Bambu tied with @Wiferneer for the runner up spot this year (J/K 😉). Either way I'm pretty impressed with Bamboozler the Bambu and I'm pretty excited to see what 2024 brings to the 3D printing world. Trying to do this with the rest of the team (Ol'Flashy the Flashforge and Cooter the Ender 3) would have been MUCH more... um, curse word inducing...
Now… I just have to decide if I'm going to keep it or give it my “Sweetheart!”
________________________________________________
If you'd like to see what I'm up to when I'm not Instructable-ing you can also find me at these places:
My Website: https://www.makerneer.com/blog
Instagram: https://www.instagram.com/makerneer
YouTube: https://www.youtube.com/@makerneer
My Etsy Shop: https://www.etsy.com/shop/Makerneer
Note: My posts may contain affiliate links. Which means when you click the marked product links in my Instructable nothing changes on your end, and I earn a small % on qualifying purchases. Thank you for your support!
2 Comments
Makerneer 3 months ago
Thanks!
Yes, I created it in Fusion 360. It was a little tricky but being able to upload the Sweethearts image as a canvas to work off helped.
Penolopy Bulnick 3 months ago
Such a cute idea for a lithophane! So, did you use Fusion to design that cute Sweethearts enclosure?
