Symptoms Detector (Pseudo - Covid19)
Introduction: Symptoms Detector (Pseudo - Covid19)
About: Electrical & Electronics Engineering student. Specializing on: Major: Signal Processing & Communications Minor: Computers (Hardware&Software) Feel free to contact me via Email: royba1999@gmail.com
***Clarification since people are not reading all the article !!!***
This is my try to help, I made it to inspire and to share my idea. it works only to detect the symptoms and NOT the covid19 itself.My major problem was and remain - to unique the disease from it's symptoms. Enjoy reading.Lets begin: ⚙️"Pseudo" COVID19 Detector, Using MQ-9 sensor. Calibration was made using:Fresh air 🌬, cool air(using 5v DC fan) 💨, fire(from a matches)🔥.How it works 🛠: 1)Calibration of the MQ-9 2)Exposure to fresh/cool/hot air (as shown in the dynamic plot- the high jump is due exposure to dense air- smoke)
Step 1: How the Graph Looks Like Depending on Temperature/Air Density
Step 2: Lets Continue
3)Calculation which transforms the air pressure/density to temperature4)if the temperature is between 36.6C-37.6 - everything is fine, otherwise the LEDS (4):[blue-common cold-sneezed nose, red-Fever, green-High particles density, white-Low particles density] are on.
So, Why "pseudo"? Well since it was never really tested on humans and i'm quite sure it is working but not necessarily for corona virus for example it can detect:Fever, common cold etc... by mistake ❌
MQ-9 Specifications📝: https://www.electronicoscaldas.com/datasheet/MQ-9_Hanwei.pdf [Recommendation: open dynamic plotter while testing] How to Calibrate the MQ-9 sensor: [full guide: https://create.arduino.cc/projecthub/electropeak/how-to-calibrate-use-mq9-gas-sensor-w-arduino-e93cb1?ref=search&ref_id=MQ-9&offset=3 ] Diagram (special thanks to ElectroPeak)
Step 3: General Knowledge About MQ- X Sensors:
Step 4: The Code
I hope you will find this project practical, fun and maybe improve it from pseudo detector to a TRUE detector!
Roy.
Step 5: SCHEMATICS
Be the First to Share
    • Fruit and Veggies Speed Challenge
    • Fandom Contest
      Fandom Contest
    • Metal Contest
      Metal Contest
    2 Comments
    Cachivache
    Cachivache
    Question 1 year ago
    Hola Roy
    ¿Se puede usar un MQ2?
    Gracias
    Alberto
    Roy Ben Avraham
    Roy Ben Avraham
    Answer 1 year ago
    Hi man, Can you write in English? Cheers.
