TECHStyle JACKET
Intro: TECHStyle JACKET
In this in demonstration I go over the process of designing my TECHStyle jacket.
Tools - Autodesk Sketchbook Pro 5
Old-school Graphire 3
Objective
- Have a Sci-fi feel to its design and a fun feel without being over the top
- Design a jacket that has a specific pouch to carry mobile devices
- A hood with a mesh vent that allow user to wear headphone on the out of the hood
Objective
STEP 1: Getting the Idea
Stage 1
* select the 2B pencil - This is my personal option you can also used the default pencil or one of the many other drawing tools available in sketchbook
Image 1 - I begin my design process by cutting the page into 4 section then roughing out some thumbnail ideas. The thumbnails all look messy, this is deliberate as I do not want them to have one lock in form or idea.
Image 2 - I create a new layer and begin working out some idea for the mesh vent for the hood.(Im thinking pharaoh head wear meet space helmet)
Image 3 - Next i setup the template to overlay my idea on.
STEP 2: Roughing Out the Ideas
Stage 2
* 2B Pencil
image 4 - continue setting up and adjusting the template layer. Create a new layer to sketch out and work out ideas.
image 5 - Using the 2B pencil with a light opacity i start roughing out idea over the template layer. Referencing to the thumbnail layer for references.
image 6 - Now hide the template layer squint your a bit eyes .This blurs the image so you can be seen from a different point of view.
image 7 - I have made adjustments to the design.
image 8 - Turn on template layer and start working on the back design.
image 9 - Turn off template layer and check the sketch.
* 2B Pencil
STEP 3: Working on Figure View & Adding Tone
Stage 3
image 9 - Sketch out a basic figure form (Stick figure)
image 10 - Add a new layer an begin roughing out the outfit design over the figure (Remember to refer to the thumbnails sketch)
image 11 - Turn on the hidden layer an check the design.
* Select maker
image 12 - Add a new layer and place it behind the sketch. Using the marker tool and a grey tone build up layer of light and dark. use the erase tool to remove greys from such area as the face and creating highlights.
image 13 - Duplicate the sketch layer and with a 2B pencil begin darkening the outing and adding definition to the sketch.
* Select maker
STEP 4: Adding Color
Stage 4
image 14 - With the outline layer on return to the grey tone layer. With the eraser tool start cleaning the sketch and removing the grey
*(Tip Switching on lock transparency acts like a mask so only color area will be effected)
image 15 - Duplicate the Grey sketch and play around with color.
STEP 5: Finial Staged
Stage 5
image 16 - Pick the marker tool to Color the front and back design. Using the eraser tool to remove and add hightlights
image 17 - Bring all three Sketched elements into a single layer. To begin finalising the layout.
Final image - Put the finial touch by Adding all necessary background elements such as texts, background style, etc
And that concludes this design process.
Thanks for reading.
Thanks for reading.
