THE DIRECT DRIVE AND ORBITER V1.5
Intro: THE DIRECT DRIVE AND ORBITER V1.5
This is an direct drive that supports ender3, ender 3S, ender 3 V2, ender 3 PRO, CR-10, CR-10 S5, CR-20, CR-10 MINI, CR-10 S4, CR-10S 3D printer.
video(make): https://youtu.be/EwfdDj4dOdA
The Ender 3 direct drive weight: about 259g (Including the stock hotend, cooling fan, the E motor extruder).
***Nozzle-to-Probe offsets { X, Y, Z }
#define NOZZLE_TO_PROBE_OFFSET { -28.75, -9, Z }
***Features:
1 Printing TPU is more convenient and faster;
2 very light weight;
3 Assembly and disassembly is very convenient(Just need to turn one screw);
4 Support Orbiter extruder: https://www.thingiverse.com/thing:4725897
5 Can also be used as a Long-Distance remote extruder;
6 Support BLtouch and 3Dtouch;
STEP 1: Print 2 Printed Parts
If there is any fluff, you can use a lighter to remove it.
STEP 2: Insert the Nuts
I used a soldering iron, heated to 330℃.
STEP 3: Install the 5015 Turbo Fan
Note: Before installing the 5015 Turbo fan, use needle nose pliers to reduce it into a V shape. Use M3X35 screws to fix.
STEP 4: Install the 3010 Fan and Fan Duct
The 3010 fan is fixed by the fan duct, and then use M3X12 screws to fix the fan duct.
STEP 5: Install the BLTouch or 3D Touch
Fix with M3X6 screws.
STEP 6: Replacing the Teflon Tube
Before replacing the Teflon tube, you need to preheat the hotend to 200°C.New Teflon tube length is 64.5mm
STEP 7: Soldering the Fan
Remove the original fan first, then solder the new fan.Pay attention to the positive and negative.
STEP 8: Install the Frame
The right side is fixed by inserting the card, and then fixed with an M3X8 screw.
STEP 9:
The Orbiter V1.5 extruder is fixed with M3X8 screws.
STEP 10: Soldering the Stepper Motor Wires
Wiring as shown.
STEP 11: Modify the E Steps to 690
remember to save.
STEP 12: Modify the E Drive Current to 0.45V
Measure with a multimeter.
STEP 13: Replacing the Spool Holder
Use M5X16 screws to fix.
