THE SCARY SKELETON BUNNY
Intro: THE SCARY SKELETON BUNNY
I was stumbling around, what to do on the easter holidays. So i decide to cut something. First of all i only want to cut the shape of a bunny. But this seems boring. So it came to my mind to engrave it with an awesome skeleton. The result looks great.
STEP 1: Choose Wood
You have the freedom to choose every type of wood. If you are unfamiliar with cutting different Materials, look at my channel (Link in my Profile). I explain everthing which you have to know about Laserworks. It is easy understandable (German) and if you just imitate my action with the program it would be a lot easier to cut the SCARY SKELETON BUNNY.
For this project i used plywood.
STEP 2: Its All About Design
After i draw the shape of the bunny as a vector, i imported a bunny skeleton picture to the background. Afterwards i draw vectorpaths for every bone in the skeleton. I attech the result of my work as a Adobe Illustrator file.
STEP 3: Export the Bitmaps
If you are finised with your preparation in Adobe Illustrator, export it to a high resolution (300ppi) bitmaps, just to ensure a good graving quality of the skeleton.
STEP 4: Make Your Project Ready for Cutting
I cut the skeleton grave with 350mm/s engraving speed and 30% Laserpower. Works great and i have a smooth engraving. Just make sure to set the intervall in engraving parameter short enough to have a good graving quality. (0.08mm works great. 0.1mm is still okay). If you dont understand the intervall parameter look at my Youtube-Channel for further information. The shape was cut with 7mm/s and 70% Laserpower. (Do not overpower your Laser) In my case 70% is the maximum Power with 17mA. Depending on the material (or woodtype) you can use these parameters as a starting point and vary it. I attach the file for you.
STEP 5: Cut It
If everything is done, just send the job to your lasercutter.
rainingfiction 7 years ago
That looks super cool!
