TV Remote Controlled Paper Planes
Intro: TV Remote Controlled Paper Planes
I love everything that flies. In my childhood I made a lot of paper airplanes, but they have a huge problem. After some minutes they fall down. So now I designed a small device that allows you to control the speed and the height of your airplane with a TV remote control. If you press any button on the remote the small motor starts to rotate the propeller and the plane accelerates. This thing can be suited to any paper plane, The weight of the full gadget is 9 grams.
The power source is a small Li-Poly battery that can power up the circuit for about 10 minutes. It takes some time until you'll learn to fly, but isn't so hard. I've had a lot of experience with this circuit. This control unit can be used for others too, can drive LEDs, motors, relays or anything. Can be used for a home-automation project too.
STEP 1: Tools and Parts
- soldering iron
- cutting tool
- glue
- crafting tools or rotary tools
- small Li-Poly battery
- a piece of PCB
- electric micro motor with propeller
- 100uF cpacitor
- 100 ohm resistor
- 220 ohm resistor
- Red LED
- BC557 transistor
- IR reciever 38kHz
- straws
- valcro
- and a plastic piece
These parts are very cheap so you can build this project from less than 6 bucks. You can replace resistors with another, but the value can't be higher than 470 ohms. So let start building!
STEP 2: Prototyping and Experiments
This step isn't so important I just took some pictures about the prototyping of the circuit. I made 5 different circuits, then chosed the circuit that can drive a small signal LED and the motor. In the next step you can see the diagramm of this circuit.
STEP 3: The Plan
Following this circuit diagramm solder together the parts.
But how it works?
The IR reciever accepts the signals from the remote control. The capacitor filters the frequency of the 38kHz signal so your LED won't blink. This is very important. The BC557 transistor amplifies the current of the output then drives the motor and the LED.
STEP 4: Soldering
You'll need to design the circuits as small you can, or the weight will be too big. My one is a little bit bigger than a coin. This is an ideal size.
STEP 5: The Plane
Fold this paper airplane by following the pictures.
STEP 6: Center of Gravity
Get a needle and a pencil, because we'll need to find the center of gravity of this plane. You'll need to situate here the control unit. I think you can see clearly everything from the pictures. Hang the plane from the needle and draw straight down. And repeat this three times.
STEP 7: Calculating the Distance
The distance between the CU (control unit) and the CoG (center of gravity) is 0.5 cm. With the formula D1xG1=D2xG2 we can calculate the distance between the CU and the motor. For me this is 4.05 cm.
Why is this important?
-If we just make a random distance the plane will fall down because isn't in balance.
STEP 8: Build the Frame
Cut a straw with a 4.05 length and glue to the plastic piece that will be suited on the plane. Glue the motor on this straw.
STEP 9: A Little More Building
Fix the CU on the plastic piece then the velcro on the other side. Glue the valcro on the battery too. Connect them then charge up and test it.
STEP 10: Testing
If you press any button the TV remote control the motor starts to spin very fast. Generates a very cool wind. the LED doubles as a battery level indicator and as a signal indicator. If the battery is charged up the LED blinks, but if not lights dimly. Now equip on the plane.
STEP 11: Equip on the Plane
Just take the CU and slide the plane in. Cut a small space for the propeller and your plane is ready to fly.
STEP 12: First Fly
Drop the plane and when it descends press a button and it will fly like a bird. On the third picture and on the fourth picture it flies very neatly.
If you liked this give a kindly vote for me and thanks for watching! ;)
168 Comments
Ivanka Thornfield 7 weeks ago
Do you have video of how to do this project, I would love to see it because I really need some help. 🥺
Hi! I’m having some trouble with making the circuit. Would you mind giving us some more details on how to design the circuit? 😓
Asad Ullah 333 4 years ago
shivamj25 5 years ago
nilsankarsahoo 5 years ago
Hiya bud 7 years ago
how long will it fly
Alexander heron the inventor 7 years ago
im so confused all my hc 05 modules r using 5v aint work at 3
GARV DON 7 years ago
how we will connect it to the remote ??
ArduinoDeXXX 7 years ago
Hi, I met your great article by viewing a similar article in Instructables. I thought that the original is yours. Therefore I ask a question to you.
It seems that the PNP transistor is connected in the un-usual direction against current in the diagram in Step3. Something important is attempted in it?
I tried the diagram in attached picture below. It works well. It contains only LED but not motor and 5V power supply instead of 3.7V. Because I don’t have either an IR receiver working with 3.7V or a small motor working with a little current.
May I ask you to tell me why the un-usual direction was selected? Thank you.
Laurar127 7 years ago
no entendi muy bien alguen me explica
hol
ctin 8 years ago
Felicitari! Foarte ingenios!
Imetomi 8 years ago
Merci!
Harsh Dethe 8 years ago
and I'm planning to make one soon ,
I would like to know if I could make it take turn ?
I mean using micro actuators or something ?
Alexander heron the inventor 8 years ago
make modif using arduino,make codes that will on and off 2 motors,im making that instructables soon
FulviaG 8 years ago
Hi I've built it but at the motor arrives just 0,5v ant it runs very slowly. also the led doesn't blinks
Imetomi 8 years ago
mountain-star-hawk 8 years ago
I am having the same problem. Is the resistor at the base the 100 ohm or the 220 ohm?
I did discover that the remote I was using was sending a very slow RF pulse so I switched it out and saw some improvement, but it is still too slow.
Imetomi 8 years ago
I haven't any idea, try to use a BC337 with a 50 ohm resistor.
