Tabbing Wire Support for Easy Cutting.
Intro: Tabbing Wire Support for Easy Cutting.
Really simple holder for tabbing wire rolls that helpes you to cut straighter and equal in size wires almost without effort :)
STEP 1: You Need:
A wood board 20x6 and about half inch thick (works a bit thinner too)
A lath 8 inch long
Bolt, 3 nuts, 4 washers
Wood glue
A couple of screws
And, of course, tabbing wire to hang on this baby!
STEP 2: Build It.
I don't think it needs a lot of explanation: cut the wooden parts at the right sizes and clean the edges of any splinters; glue and screw or nail them together. Drill a hole at the top of the lath and put in the screw that will hold the tabbing wire roll. You also need a small wood piece, or a thick nail, or a pen cut at the proper size (about 2-3 inches) fixed with the remaining wire holders to make the 0 mark, this is where you cut the wire after you unrolled it to the desired lenght.
Hopefuly I've been clear enough explaining this step :(
STEP 3: Result:
The only thing left to do is make the marks corresponding to the sizes you want the wires to be.
Thank you for reading :)
seamster 9 years ago
Great project. Thanks for sharing this!
