Introduction: Table to Hold the Herbs
Example for first
A special thanks to Elisa Puntual for inspiration
LINK |Pinterest
Step 1: First Step Keep Materials & Tools
Simply obtain the following material & tools:
Materials:
1 table of old wood
14 tacks
7 jars of spices
1 roll of copper wire
2 straight brackets
3 anchors with screws
Tools:
1 screwdriver
1 hand drill
1 cable stripper
1 pliers
1 hammer
1 pencil
Step 2: Process
Process:
The screwdriver was used for the distances and the little sign of recognition for the hole to be do subsequently with the drill.
Step 3: After Drilling
After drilling the holes, hammer nails, making sure that they are positioned at the center, then so be able to insert the copper wire
Step 4: Fix Jars
With stranded copper, wrap well for number 3 or 4 laps the jar available, it is necessary to accurately move the ends of the copper cable to the extreme sides of the hole so to embrace the nail which in this case performs the function of tie.
Step 5: Work Completed
Work completed
Step 6: Fix to the Wall
After have applied the double brackets and having procured the plugs and screws, place of valve of wood to the wall in the manner as straight as possible and put a pencil to make holes in the sign for holes with the drill, after piercing the wall plugs and screw the board to the wall.
Step 7: Work Is Completed
On completion of work as well if you want to compost for vegetable you could put some small pebbles inside of jars of foam needed only for the bottom, then you can enter the ground with your hands or if you prefer using a small spoon. Now you can pick the planting of herbs you like best ... he then remember to water them thoroughly ;-).
If I'm lucky and the herbs that I planted will grow and survive me, I shall post the final picture with the herbs ;).
Thanks for visiting.
Step 8: The Plants Grow
Let's say, the little basil ask for water twice a day, if you leave wither.
