Tackle Box Organization Hack
Intro: Tackle Box Organization Hack
This is a simple way to organize your fishing hooks and spinners for your tackle box. It will help you find your equipment with ease and be able to select the equipment without being cut by a hook.
Supplies needed :
Glue gun or other adhesive
tackle box
Styrofoam
paperclip
cutting tool
STEP 1: Pick a Slot in the Tackle Box
STEP 2: Measure the Slot
STEP 3: Cut a Square of Styrofoam Using the Previous Measurements
Use caution while working with knives or cutting tools
STEP 4: Make Sure the Square Is Straight and Doesn't Have Any Cracks
STEP 5: Use a Glue Gun or Other Adhesive to Put in the Slot of Choice
Use caution while working with adhesive and glue guns
STEP 6: Place the Styrofoam Over the Glued Slot and Press Firmly
alllow 1 minute to dry
6 Comments
The great building guy 8 years ago
environment*
I just use safety pins to do hook size and swivels. A lot cheaper and better for the envi
TheOriginalNerd 8 years ago
Good idea. I'd say great idea because I know what a pain (in more ways then one) it can be to untangle and retrieve a single hook from a pile of them, but I can't say great because there's something you need to take into account. That is that as you use it, it will tear up the little Styrofoam balls and as that happens those balls/flakes will go everywhere, including into the environment where you'll be fishing. Then birds and fish will most likely mistake the balls of plastic foam as food an eat it. Even then some will recognize it doesn't taste right an spit it out, but some will not and that will obviously, be hazardous to their health.
I might suggest adding a layer of some type on top of the Styrofoam to hold back the flakes and balls as the hooks are removed. The layer could be cloth, rubber, even plastic. Trials would have to be done to see what works best.
Or better yet, use that other kind of plastic foam packing that isn't made of tiny foam balls. It's more of a spongy foam that comes in all kinds of colors.
That Redhead 8 years ago
Nice!
somewhiteguy 8 years ago
My grandfather's old tackle box had a strip of cork in the top that he used for the same purpose. Why isn't this standard in most boxes? Great idea and easily replaced when damaged.
DamianTheGreat 8 years ago
Yeah there should be a standard hook holder in tackle boxes. I got my inspiration for this instructable from people who used cork for there hooks. Thanks for the feedback.
