Taking Out Little Dents
Intro: Taking Out Little Dents
For more auto tips, visit PopularMechanics.com.
To fix a single dent (like the one pictured), it is probably not worth the time and paperwork it takes to fill out the insurance claim. Besides doing it your is easy enough --the tools won't cost much, and the instructions won't make your head spin.
You can bang out that dent, fill those nicks, and refinish that paint job with a body hammer and dolly, a sander with a 36-grit disc to remove paint, a putty knife and body filler squeegees to apply filler, a bodyworking file ("cheese grater") to level the filler, a stroke sander to smooth it, an air compressor and spray gun to apply primer/surfacer/paint, and a buffer to shine it all up. Thanks to today's body repair materials-better paints, improved fillers and two-part primer/surfacers-bodywork and painting to a mirrorlike finish has never been easier to do in your own shop.
STEP 1: Bang It Out
To remove a dent, first gain access to the back side of the body panel by removing items like headlight buckets, inner fenders, door panels and interior trim. Then, place a dolly on the outside of the dent and then hammer on the inside of the dent, striking the metal against the dolly. The key is to go slowly and work around the circumference of the dent, banging it out until it lies just below the undamaged area. After the dent is out, put the dolly on the inside of the dent, then tap the area surrounding the outside of the dent to knock in any high spots.
STEP 2: Prep and Apply Filler
When you're sure all the sheetmetal is just slightly below the surface of the surrounding area, use a disc sander with 36-grit paper to remove all paint and primer from the dent and surrounding area. This will give the body filler a rough surface (called tooth) to hang on to once it has hardened. After thoroughly mixing the filler with hardener, smooth it on the damaged area with a plastic filler applicator. The filler semihardens in 10 to 15 minutes to the consistency of cheddar cheese.
STEP 3: Smooth and Sand Down the Filler
At this point it's easy to smooth with a body file. Use the file to knock the filler down so it is slightly higher than the finished repair will be. After about 15 to 30 minutes, the filler becomes hard.At this point you can use a hand or air-powered stroke sander with 80-grit paper to bring the filler down to the level of the body. If you see any bright, shiny metal spots in or around the filler, those areas are high. Use the pointed (pick) end of a body hammer to tap them in slightly, then refill and resand.
STEP 4: Prime and Surface
Before the repaired area can be painted, scratches, pits and waves must be completely removed or they'll show up as reflections. A primer/surfacer forms a thick layer of material over the area, which is then sanded down to make the repair smooth and level. Two-part primer/surfacers, consisting of the primer and a hardening agent, allow a thick layer to be applied over the repair in only one or two coats. After a half-hour of drying the primer is ready for sanding.
(Warning! Before applying any primer or paint, be sure to wear a respirator rated for organic solvents.)
STEP 5: Contrast Paint the Primer/Surfacer
Before you sand, apply a light mist of black lacquer from a spray can over the repaired area. This contrast coating will reveal imperfections that will disappear as you sand. Make sure there is adequate ventilation, and also make sure that pilot lights and other flame sources in the general area are turned off.
STEP 6: Prep for Paint
To sand the primer, use a rubber sanding block and 400-grit waterproof sand paper. The trick is to sand lightly while frequently dipping the paper in a bucket of water to keep it clean. When all of the black contrast coat has disappeared, the repaired area is finished. Then clean and prepare the surface surrounding the repair to accept paint then wipe the entire panel with a solvent-based wax remover. Now, wetsand the area again to be painted with 600-grit waterproof sandpaper. If you're going to blend the paint into the original paint, make sure to sand an area larger than the area where you will be applying the paint. Thoroughly rinse the area, let it dry and then wipe again with wax remover. Mask off adjacent panels, then cover nearby wheels and major portions of the car with painter's plastic sheeting to shield it from overspray.
STEP 7: Paint
Mix the basecoat with the appropriate amount and type of solvent according to the maker's instructions. Before spraying, gently wipe the area to be painted with a tack rag, then spray the panel or repaired area. If you are blending, apply only enough basecoat to cover the repaired area, then taper off as you move away from the repair. After the basecoat has dried thoroughly, you'll notice its finish is quite dull. This is so the clearcoat will adhere tightly. Do not sand the basecoat before applying the clearcoat. After mixing the clearcoat with hardener, according to the manufacturer's instructions, apply a medium wet coat and let it flash dry 5 minutes or so before applying a second coat. After letting the clearcoat dry for an hour, remove all masking tape. Then wait one day before polishing.
STEP 8: Polish
Chances are the finish already looks pretty good. But to make it flawless, it pays to color-sand and polish the entire repair. Use 1500-grit sandpaper to flatten the finish, followed by rubbing compound to remove the scratches left by the sandpaper. Finish up with polishing compound to make the finish flawless. After polishing, wait one month to apply wax.
42 Comments
bleachworthy 16 years ago
jkl78 9 years ago
Overkill Much?
strangebike 11 years ago
yo man 14 years ago
I hope this helps
strayturk 11 years ago
http://www.wisebread.com/remove-car-dents-quickly-and-cheaply
triumphman 11 years ago
id301 12 years ago
chaitanyak 12 years ago
heartlessangel7 13 years ago
macmundi 13 years ago
lampajoo 15 years ago
adam395 13 years ago
WhirringWheels 14 years ago
rouge180 14 years ago
attilam 15 years ago
Derin 15 years ago
Jalakahops 16 years ago
heartlessangel7 15 years ago
WolfVecho 15 years ago
