Temperature and Humidity Datalogger + Webserver
Intro: Temperature and Humidity Datalogger + Webserver
In this instructable (my first instructable) we will create a temperature and humidity datalogger adding the posibility to access the data by web.
The new arduino ethernet makes everything sooooooo easy that it looks like magic. In the same board you get: an ATMega 328, ethernet conectivity, sd card
Only need a RTC (Real Time Clock) in order to have a full datalogger. I will plan to make another instructable about how to conect a RTC to this board.
You can connect to my own arduino server in order to see my server room temperature.
STEP 1: The Basic Stuff
Lets me show how easy is to make a datalogger that saves sensor data in a SD card and allow remote access by web using any browser.
We will use three DHT11 sensor as source of data. Every DHT11 give us temperature and humidity data. They are really cheap (2€ iin ebay) and more or less acurrate ;-) : 2 Celsius degree and 5% of humidity. In the case you want more acurrate data, the DHT22 could be your election.
I apologize for using Celsius degrees. That is because I radicate in Spain. Changing the units to Fahrenheit degrees it is really easy.
STEP 2: Connect Arduino to the Sensor
The sensor use a proper protocol, using one wire transmisition, mudulating the value in time, first you get the temperature, then the humidity value. It's something similar to pwm. The orthers used pins are Vdd and Gnd.
In order to facilitate the code we are going to use a library for DHT11 comunication. You can download the library from arduino-info.
To connect the sensors, you only have to connect all the Vdd pins to the 5+ and the Gnd pins to Gnd of arduino. In this example the data of every sensor is connected to the pins 2,3 and 4.
A basic program could be this one:
#include
dht11 DHT11;
void setup()
Serial.begin(9600);
void getdata(int iPuerto)
int chk = DHT11.read(iPuerto);
Serial.print("Sensor ");
Serial.print(iPuerto);
Serial.print(" ");
switch (chk)
case 0:
Serial.print((float)DHT11.humidity, 2);
Serial.print(" % ");
Serial.print((float)DHT11.temperature, 2);
Serial.println(" o C");
break;
case -1: Serial.println(" Checksum error"); break;
case -2: Serial.println(" Time out error"); break;
default: Serial.println(" Unknown error"); break;
void loop()
getdata(2);
getdata(3);
getdata(4);
delay(200);
I have trouble downloading the program using the current Arduino IDE 0022 under ubuntu. In order to solve then I have to modify the boards.txt file. An bug have been reported to the arduino comunity.
#include
dht11 DHT11;
void setup()
Serial.begin(9600);
Serial.print(" ");
switch (chk)
case 0:
break;
void loop()
getdata(2);
getdata(3);
getdata(4);
delay(200);
STEP 3: Connect Arduino to Internet
Using the webserver example it is really easy to put your data on internet.
The previous Sketch modified could be in order to acept http request:
#include
#include
#include
dht11 DHT11;
#define nSensores 3
int puertos[nSensores];
float fHumedades[nSensores];
float fTemperaturas[nSensores];
int iNVisitas=0;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xEE, 0xEE };
byte ip[] = { 192,168,1, 177 };
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
Server server(666);
void setup()
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.begin(115200);
puertos={2,3,4};
void getdata(int iIndice)
int chk = DHT11.read(puertos[iIndice]);
fHumedades[iIndice]=-1;
fTemperaturas[iIndice]=-1;
Serial.print(iIndice);
Serial.print(" ");
switch (chk)
case 0:
fHumedades[iIndice]=(float)DHT11.humidity;
Serial.print(fHumedades[iIndice], 2);
fTemperaturas[iIndice]=(float)DHT11.temperature;
Serial.print(fTemperaturas[iIndice], 2);
break;
void loop()
// listen for incoming clients
Client client = server.available();
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == ' ' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
// output the value of each analog input pin
for(int i=0;i // for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
client.print("sensor ");
client.print(i);
client.print(": ");
if(fHumedades[i]==-1)
client.print(" error leyendo el sensor");
else
client.print(fHumedades[i], 2);
client.print(" % ");
client.print(fTemperaturas[i], 2);
client.println(" o C");
client.println("
client.print((iNVisitas++)/2);
client.println(" visitas
break;
if (c == ' ') {
// you're starting a new line
else if (c != ' ') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
else
for(int i=0;i getdata(i);
delay(200);
Where I am using my proper network configuration. In order to use your configuration, only change the mac and ip values.
#include
#include
#include
dht11 DHT11;
#define nSensores 3
int iNVisitas=0;
Server server(666);
void setup()
server.begin();
puertos={2,3,4};
Serial.print(" ");
switch (chk)
case 0:
break;
void loop()
if (client) {
client.println();
client.print(i);
client.print(": ");
else
client.println("
break;
if (c == ' ') {
delay(1);
client.stop();
else
delay(200);
STEP 4: Save Data to a Sd Card
Saving the data to a sd card is really easy for the ehternet arduino.
The SD must be fat16 or fat32 formated
Only need to Including the sd library, initialize the sd library and open and write to a file
Here is the code:
#include
#include
#include
#include
dht11 DHT11;
#define nSensores 3
int nFilas=0;
int nFiles=0;
File file;
int iNVisitas=0;
Server server(666);
void setup()
server.begin();
puertos={2,3,4};
pinMode(10, OUTPUT);
if (!SD.begin(4))
Serial.println("Error inicializando SD");
nFiles=-1;
else
nFiles=0;
Serial.println("SD initializada.");
Serial.print(" ");
switch (chk)
case 0:
break;
void loop()
if (client) {
client.println();
client.print(i);
client.print(": ");
else
client.println("
break;
if (c == ' ') {
delay(1);
client.stop();
else
//if(nFiles>=0 && file)
file= SD.open("datalog.txt", FILE_WRITE);
String data="";
for(int i=0;i {
getdata(i);
data+=String(nFilas)+";"+String(i)+";"+String((int)fHumedades[i])+";"+String((int)fTemperaturas[i])+" ";
if(file)
file.print(data);
Serial.print(data);
file.close();
nFilas++;
delay(200);
Here is the code:
#include
#include
#include
#include
dht11 DHT11;
#define nSensores 3
int nFilas=0;
int nFiles=0;
File file;
int iNVisitas=0;
Server server(666);
void setup()
server.begin();
puertos={2,3,4};
if (!SD.begin(4))
nFiles=-1;
else
nFiles=0;
Serial.print(" ");
switch (chk)
case 0:
break;
void loop()
if (client) {
client.println();
client.print(i);
client.print(": ");
else
client.println("
break;
if (c == ' ') {
delay(1);
client.stop();
else
String data="";
for(int i=0;i {
getdata(i);
if(file)
file.print(data);
Serial.print(data);
file.close();
nFilas++;
delay(200);
15 Comments
mabedin1 9 years ago
awsm to start.
mmo6 11 years ago
javacasm 11 years ago
mmo6 11 years ago
client.stop();
else
String data="";
for(int i=0;i
if(file)
file.println(data);
Serial.println(data);
file.close();
nFilas++;
delay(1000);
for(int i=0;i getdataDHT(i);
delay(1000);
getdataOneWire();
This is the code I'm using now in a bit more complex project. You can remove the OneWire part
I hope this helps
#include <SPI.h>
#include <Ethernet.h>
#include <OneWire.h>
#include <dht11.h> // Descargamos la librería desde http://arduino-info.wikispaces.com/DHT11-Humidity-TempSensor
dht11 DHT11;
#define nSensoresDHT 6
#define nSensoresOneWire 3
int puertosDHT[]={2,3,5,6,7,8}; // ¿Por qué nos saltamos el 4?
int puertoOneWire=9;
OneWire ds(puertoOneWire);
float fHumedades[nSensoresDHT];
float fTemperaturas[nSensoresDHT+nSensoresOneWire];
int iNVisitas=0;
EthernetServer server(666);
void setup()
server.begin();
float tMin=100;
float tMax=0;
float tMedia=0;
int contador=0;
void getdataOneWire()
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius;
if ( !ds.search(addr)) {
Serial.print(contador);
Serial.println(" DS18x20 encontrados");
Serial.print("Tmax=");
Serial.print(tMax);
Serial.print(" Tmin=");
Serial.print(tMin);
Serial.print(" tmedia=");
Serial.println( tMedia/contador);
ds.reset_search();
contador=0;
tMedia=0;
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
if(addr[i]<16)
Serial.print(" 0");
else
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
// Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.print(" DS18S20"); // or old DS1820
type_s = 1;
break;
case 0x28:
Serial.print(" DS18B20");
type_s = 0;
break;
case 0x22:
Serial.print(" DS1822");
type_s = 0;
break;
default:
Serial.print("Not a DS18x20");
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
// convert the data to actual temperature
unsigned int raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// count remain gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw << 3; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fTemperaturas[nSensoresDHT+contador]=celsius;
if(tMin>celsius)
tMin=celsius;
if(tMax<celsius)
tMax=celsius;
tMedia+=celsius;
Serial.print(" Temp.= ");
Serial.print(celsius);
Serial.println("C");
contador++;
void getdataDHT(int iIndice)
int chk = DHT11.read(puertosDHT[iIndice]);
Serial.print(" ");
switch (chk)
case 0:
break;
void loop()
EthernetClient client = server.available();
String sURL;
if (client) {
if (c == '\n' && currentLineIsBlank) {
sURL=sURL.substring(0,9);
Serial.println(sURL);
if(sURL.endsWith("csv "))
for(int i=0;i<nSensoresDHT;i++){
client.print(";");
client.print(";");
for(int i=0;i<nSensoresOneWire;i++){
client.print(fTemperaturas[nSensoresDHT+i]);
client.print(";");
client.println("");
else
client.println();
// client.println("<meta http-equiv=\"refresh\" content=\"1\" />"); //Autorefresh de la página
client.print("sensorDHT ");
client.print(i);
client.print(": ");
else
client.println(" C");
client.println("<br />");
client.print("sensorOneWire ");
client.print(i);
client.print(": ");
client.println(" C<br />");
client.println(" visitas <br />");
break;
if (c == '\n') {
else if (c != '\r') {
sURL+=c;
delay(1);
client.stop();
else
getdataDHT(i);
delay(100);
getdataOneWire();
mmo6 11 years ago
sensor 0: error leyendo el sensor
sensor 1: error leyendo el sensor
sensor 2: error leyendo el sensor
i think there are much more differences between old and new versions
mmo6 11 years ago
You can fix it changing the declaration of puertos with this one
int puertos[]={2,3,4};
I hope this helps
mmo6 11 years ago
can you say why does line
puertos={2,3,4};
give me an error?
expected primary expression before { token
Maybe my code need a revision for arduino 1.0
jabujavi 11 years ago
No serás forococheros verdad? te encontrarias un monton de cosas en la plataforma...
saraca_92 11 years ago
so nice.
i can try =)
javacasm 12 years ago
Computothought 12 years ago
I'll check it
