Temperature and Humidity - SI7021
Intro: Temperature and Humidity - SI7021
Reviewed by our friend Enrique. Hope it will be useful for you.
Although sometimes it does not seem we are surrounded by sensors in almost all electronic devices (and some mechanical) that we have around us, you just have to think of a smart phone how many electronic sensors have? Light, accelerometer, camera, gyroscope, magnetometer, thermometers, voltmeter, ammeter, etc. And it is a device that can take wrong decisions if we do not provide Him from the sensors need for you to know that around occurs, thinks only of any of us, what happens if we lose all senses, sight, taste, smell, touch , ear, because at first glance we have very difficult to understand what happens around us.
There are sensors to measure any physical parameter you can think of and many technologies and protocols with which to communicate with them, each will have his.
STEP 1:
In this case we analyze the temperature SI7021 hand IcStation and humidity sensor. This sensor will be able to read both physical quantities, transform them into digital values and store them in your memory bank, so that when we ask through I2C one of the two parameters, the module will return 2 bytes that correspond to the value we are asking. As we see in the block diagram that provides the manufacturer of integrated SI7021 circuit, the circuit integrates an ADC to read the values of both sensors and send the reading to the logic block that handles calibrate and store the readings later when ask you for a value, the I2C interface to access the logic module, retrieve the value and return it via I2C.
As you may have been able to find out we will contact integrated through I2C for different bytes containing the values of temperature and humidity, if we analyze carefully the datasheet SI7021 see how each value is made up of 2 bytes ie 16 bits but through I2C we can only transmit 8 bits in a single response and therefore to convey the full value we have to get 2 responses.
STEP 2:
Attack
This time for a change not use Arduino to communicate with the integrated SI7021 and therefore we must have the wire.h library on which we have already discussed above, the workflow to get, for example, the temperature will be:
1. Start the transmission with the slave device (SI7021)
2. Send 0xE3 byte which indicate the sensor we want the temperature value
3. End transmission
4. Ask the SI7021 2 bytes that make up the temperature value
5. To receive and combine the 2 bytes on a 16-bit word
6. Calculate the temperature value to the equation:
Temperatura =(175.72·Temp code)÷ 65536 - 46.85
Where temperature is in ° C and Tempcore is the word of 16 bits
Humidity = (125 · RH Code)÷ 65536 - 6
Where humidity is in% and Rhode is the word of 16 bits. For RHCode will use the byte 0xE5 0xE3 instead of in step 2.
Obviously you have more integrated I2C we can send commands to obtain or modify different values and all of them can see in this table that provides the manufacturer of the component datasheet.
Table 2C command Source: Silicon Labs
Using it is relatively easy
As you see is fairly easy to use and is based on asking and receiving bytes via I2C, so if you understand the concept is quite likely to understand the code we will use in Arduino.
Placa SCL SDA
Arduino Uno A5 A4
Arduino Mega 21 21
Arduino Leonardo 3 2
Arduino Due 21 20
STEP 3:
Remember that we are talking about a I2C device therefore
we have to use the corresponding pins of our microcontroller and if we are using the module does not have pullup resistors have to put them. If we look at the module IcStation carefully we see that already included on the plate the two resistors, so it is not necessary to include them on our own and also includes capacitor 0.1 uF you need integrated between Vcc and GND to stabilize its feeding.
A very important fact that you have to consider when connecting the integrated works is that NO 3.3v 5v
STEP 4: Code for Arduino
SI7021 to serial port
#include
//General variables
int temp[2], hum[5];
double temp_code, rh_code;
float temperature, RH;
//Direccin del sensor
byte direccion = 0x40;
void setup()
Wire.begin(); //Initialize I2C
Serial.begin(9600); //Initialize Serial Port
void loop()
Wire.beginTransmission(direccion); //Begin comunication with the slave
Wire.write(0xE3); //Send 0xE3 in order to read the temperature
Wire.endTransmission();
Wire.requestFrom(direccion,2); //Request 2 bytes
if(Wire.available()<=2){ //If bytes are recieved
temp[0] = Wire.read(); //Save it on temp
temp[1] = Wire.read();
//Calc the temperature
temp_code = (temp[0]<<8) + temp[1];
temperature = ((175.72 * temp_code)/65536)-46.85;
Serial.print(temperature);
Serial.print(" C ");
Wire.write(0xE5); //Ask for Relatative humidity
if(Wire.available()<=2);
hum[0] = Wire.read();
hum[1] = Wire.read();
rh_code = (hum[0]<<8) + hum[1];
RH = ((125*rh_code)/65536)-6;
Serial.print(RH);
Serial.println(" %");
delay(500);
STEP 5:
Precision
Let's talk about the accuracy of the readings and no sensor is perfect and always a mistake in this case will normally 0.4 ° C for temperature and between 2 and 3% moisture committed however these values are affected with the progression of readings and this variation we can see thanks to graphics that provides the manufacturer.
In both graphs we see that it is good enough for the applications that we will get to perform with this sensor except when we arrived at the extremes of temperature and humidity reading error increases. So we'd better choose the proper range.
Finally, the sensor sponsor comes from www.icstation.com
The sensor is only $5.99 in the fowllowing week: http://goo.gl/Diyroi
You can have a detailed introduction in the video: https://goo.gl/n6PJS1
If you some awesome ideas about mudule, please feel free to contact us: icstation13@gmail.com
