Temple: Placing the Columns
Intro: Temple: Placing the Columns
Now it's time to place the columns.
Instructions
- Find the columns and select them.
- Continue to the next step.
STEP 1: Move the Columns
Continue positioning the columns.
Instructions
- Move the columns so that they cover the gaps between the walls/arcs.
STEP 2: Copy Pointed Dome
Time to add the pointed domes.
Instructions
- Find the pointed dome and position the camera to see the bottom.
- Press W to choose the Workplane Tool and select the bottom surface.
- With the pointed dome selected, press CTRL+C to create a copy in the clipboard.
STEP 3: Paste Copy of Pointed Dome
Make more copies of the pointed dome.
Instructions
- Press W to choose the Workplane Tool and select the top surface of the column.
- Press CTRL+V to paste a copy of the pointed dome on top of the column.
- If the dome is pointing down, rotate it so that it is pointing up.
STEP 4: Continue Adding the Domes
Keep up the good work, continue adding the domes.
Instructions
- Make a duplicate of the pointed dome and move it to the opposite column.
STEP 5: Copy the Column Base
Now we need to add the column base to each column.
Instructions
- Copy the base of the columns to cover the next two corners of the wall/arch.
STEP 6: Copy the Small Dome
Repeat the process to the small dome.
Instructions
- Press W to choose the Workplane Tool and position the camera to see the bottom of the small dome.
- Select the bottom surface of the dome.
- With the dome selected, press CTRL+C to copy small dome.
STEP 7: Paste the Small Dome
Instructions
- Position the camera to view the uncapped column.
STEP 8: Paste Copy of Small Dome
Instructions
STEP 9: Duplicate Small Dome to Other Side
Instructions
- With the small dome selected, make a duplicate of it.
- Move the duplicate of the small dome on top of the opposite column.
- Continue to the next lesson.
