The Best Wood Splitter Ever
Intro: The Best Wood Splitter Ever
you will thank me for this one!
STEP 1: Materials
1st. You're going to need...1. Chainsaw
2. A tree
3. Some 2x4
4.hammer
5.nails
6.bolt washers
7.bolts
8.drill
STEP 2: Assembly
Alright, it's simple as it sounds. Take the 2x4 and cut four pieces out. Doesn't matter how long they are, just make sure they are able to be nailed around the sides of the tree you have cut. (You're tree should be a little higher then knee length when you cut it). After you have nailed a box around your tree, you next take the tire, and put the tire on top of the tree where you 2x4 box is that you nailed into the tree multiple times (nail the hell out of it, you are using it for splitting wood so it doesn't have to look pretty). After your tire is lined up with the box, pre drill holes through the tire and then take your bolts and washers and put the washer down, then put the holy through the washer and you pre-drilled hole in the tire and start to drill into the wood. After you have completed this task a couple of times around the tire (you should put about 4 bolts and washers into the tire that goes into the wood, but hey, the more the merrier!) and 'Walah! You have your first wood splitter helper. Take a whack as many times as you want
STEP 3: Safety
The tire will absorb all of the blows of your axe that you are using so if you miss and hit the tire, don't worry, it won't do anything harmful to you or your log splitter! Plus, all the wood stays inside the tire and you don't need to constantly bend down and keep picking up your split wood! Happy splitting!
STEP 4: Video of It in Action!
here ya go for those who want to see it
11 Comments
Blakew55 9 years ago
Hill dweller 8 years ago
This loo awesome. The main thought for me is saving time and my back. Will definitely try it.
Ianme 9 years ago
thatdude1234567893828234 9 years ago
man, you have no idea how awesome this is. I have been splitting logs for 10+ years and have never thought of something like this. I used to just do it the ol fashion way and split them right in half on a piece of log and theyd go flying. I built this thanks to your help and now i literally can split 2x the logs way faster then i did before. Thanks man, peace.
Bbenassi25 9 years ago
jwilliams197 9 years ago
tomatoskins 9 years ago
Growing up we had a hydraulic log splitter made from an old hydraulic ram off a dump truck. It was a beast!
Mindmapper1 9 years ago
mmm if you cant hit the top of a piece of wood with an axe you probably should not be using it in the first instance! I really dont see the point of this other than to create a hazard and increase the risk.
