Paper Glider/Plane, the Mighty Falcon
Intro: Paper Glider/Plane, the Mighty Falcon
Important.... This instructable is an entry in Paper Airplane Contest 10.
Yes, It is cool with a thin A4+tips in last step.
STEP 1: Prepair.........
Prepair Your Tools and ingredients.
STEP 2: Cut Cut Cut........... Fold Fold Fold......... Points Points Points........
Grab an angle (a corner) and fold it to make a triangle with some extra piece. Then carefully rip the extra side because you are going to need the extra part later. Don't make a mess. Keep the extra part and go on. You will enfold it and grab the another corner and fold it to the facing corner. Later, take the top side and fold it down EXACTLY BECAUSE YOU MAKE A HALF MM MISTAKE, ALL ARE GOING TO BE MESSY. PLEASE READ ALL THE REMARKS ON EACH OF THE PICTURE TO BE MORE EASIER.
STEP 3: A Bit Difficult.........
Points From Step 2 Are Very Important....... New Points Here Again At the Last Picture.......
STEP 4: OK......
Ok... More Points Form Step 3.... And More Points here......
STEP 5: A Bit Complicated..........
Points are most important.......
STEP 6: Last Step........... Yay!!!!!
Hang on. The last step.
To Fly..: Hold the plane from the bottom (see step 6, this step, 11th picture) and throw about 45 degrees up.
Tip: Fold the paper glider half symmetrically. That is the best result. If you wanna control the plane in advance.........
Up: Roll up the tail and release it. Be careful not to hurt it or fold it. Don't roll too much.
Down: Roll down the tail and release it. Be careful not to hurt it or fold it. Don't roll too much.
Left Turns: Twist the left wing carefully counter clockwise. Not too much or you will hurt it.
Right Turns: Twist the right wing carefully clockwise. Not too much or you will hurt it.
Extreme Left Roll: Twist the left wing counter clockwise and the right wing clockwise.
Extreme Right Roll: Twist the left wing clockwise and the right wing counter clockwise.
Extreme Performance: Fold the paper glider half symmetrically. Make all to be straight. No curve wings. No anything. Yes nothing. I mean no wound. Then unfold to a bit slightly more than 90 degrees (between the two wings). After that, slightly curve down the wings. It should look like a V shape that is curved down. Best results!
PLEASE DO LEAVE COMMENTS, ASK QUESTIONS, DON'T FEEL SHY. THANK YOU!
3 Comments
22181 8 years ago
TejasT1 9 years ago
Cool. i liked the idea very much. i attached wheels to it made a launcher for it and now my little brother loves it. Thanks.
Aron313 12 years ago
