The Cube of Curiosity (with Manual Tilt Sensor)
Intro: The Cube of Curiosity (with Manual Tilt Sensor)
Hello everyone. This project is all about a crazy what-to-do??? device. The use of it's parts have endless possibilities. We can keep our favorite small things like in-ear headphones, or kept on the desk as a decor when the lights are off, kept as a keychain or key dock, or else the keys can be kept inside too. This can also be kept in the pocket (of course, a large pocket.). you can also gift this gift box as the gift. And this an extremely simple project, which contains a simple, manual and physical tilt sensor.
STEP 1: Things Needed
Most of these things will be available even on the garage, where I found out these.
Basics:
1) A firm and small box. cardboard and plastic recommended, and you can also decorate them.
2) Two LEDs. ( One with multi color and another one with white is purely recommended.)
3)battery(s). I always use my trustworthy 9v battery.
4) wires. to connect everything.
Tilt Sensor:
1) A small spring. It can be found even on clickable ballpoint pens.
2) A large bead for the weight above the spring
3) copper wire. (that is the wire without insulation.)
4) bendable steel wire.
Tools: optional.
1) sticky tape or duct tape,
2) stapler
3) sugru, or modelling clay
4) solid battery connecting plugs.
And now we're ready to go.
Basics:
Tilt Sensor:
Tools: optional.
2) stapler
STEP 2: Making the Part of Tilt Sensor.
This is very easy. first, stretch out the spring so that it can respond to slight movements. Then, tape the bead to the top of the spring. this is because the bead gives some weight and makes the spring to wobble. Then take the steel wire and bend it so that there is an ''o'' like shape at the top horizontally and a ''j'' like shape vertically, and make sure that the bead is not touching the circle when inside and also the circle is not too far from the bead.
STEP 3: Making the Circuit
first, connect the wires from the plug into the multi color LED. then from the first LED, connect the positive (+) to the second LED, and negative/ground(-) in the spring. then spin the copper wire touching the spring (the spring conducts electricity) all over the bead.
also spin the copper wire on the bendable steel wire from top to bottom especially on the circle. and connect that to the ground/negative(-) of the LED.
STEP 4: Assembling the Circuit Into the Cube.
First, mount the battery on a place with tape. Now from the plug, connect the first LED to the edge of the box. from the led, keep sugru or modelling clay on another edge in the way that the bead is inside the circle but not touching it. from there, connect the second LED to the roof of the cube, where it can be seen above. now plug it to the battery and test wether the whole thing is working.
STEP 5: Finishing
You can paint your favorite designs on the box, and poke some holes on all the sides, so that the light will be visible as dots like stars.
then the cover the flooring full of wires with another piece of cardboard. now plug it in, and your curiosity cube is ready.
enjoy with it. If you liked this instructable, please vote this.
