The Easy, Ultimate Pencil Grip
Introduction: The Easy, Ultimate Pencil Grip
A Quick , easy way to make yourself a decent homemade pencil grip.
Step 1: Materials
the only materials include
1. a pencil
2. a rubber band
Step 2: Process
1. cut the rubber band in half
2. begin tightly wraping the band around the pencil
3. to keep it in place, overlap aroung the ends of the band (see picture)
Step 3: Finish!!!
Now that your done, go out and impress your peers with your amazing homemede pencil grip!!!!
Just added!!!
because of the numerous complaints, i added another picture of grip options for your pencil.Try it out on your own to see if you can make it any better!
Be the First to Share
    • Photography Challenge
    • One Board Contest
      One Board Contest
    • Raspberry Pi Contest
    6 Comments
    pocketwatch
    pocketwatch
    14 years ago on Introduction
    If you just have slippage issues this should be great! It's only if you clench pencils too tightly and need a soft grip that this won't work.
    shooby
    shooby
    The rubber band might not slip, but if it is the type with a square cross-section, then it will be able to roll quite easily. I recommend using the flat type. Although first and foremost, I recommend not doing this at all. What happens when you sharpen the pencil and it changes in length?
    GorillazMiko
    GorillazMiko
    aar000n3y is right it could slip up and down, but it still looks cool.
    Aar000n3y
    Aar000n3y
    This grip wouldn't work well. The rubber band can easily slide up and down, and it it doesn't cushion the pencil. It probably doesn't even stay on well since the rubber band could just loosen and the overlapped ends would just fall off.
    Patrik
    Patrik
    I assume this is purely decorative, rather than giving any functional benefit (i.e. less finger strain/soreness after holding the pencil for a long time)?
