The Electric Heated Sweater
Intro: The Electric Heated Sweater
Hey Guys welcome to our Entry for the Sew Contest Ins. We made an Electric Heated Sweater that uses a 9v battery to heat up your sweater. It works great yall should give it a shot. Just make sure to follow the instructions and you use a sweater that you dont really love! cuz you wont be able to wash this sweater EVER AGAIN!
Important safety point: only use this is a pure-wool sweater, or one with proven heat resistance. Many synthetic fibres melt at surprisingly low temperatures
Visit our website at www.hm-innovations.com for additional videos and projects. We hope you enjoy what we did :)
STEP 1: Getting Your 20 Gauge Wire
You have to meassure your 20 gauge ENAMEL copper wire to your desired lenght. Usually about 5-6 feet. This really depends on the size of your sweater :P
STEP 2: Start to Weaver Your Sweater With Your Wire
The next step is to start to weave your sweater with your copper wire in a zig zag motion. You will be using the Copper wire instead of a needle and thread Start your weave from about 1" from the top and 1" from the left shoulder. (or right depending on how you look at it)
You have to make sure that you weave in between the two layers of your sweater, you dont want it to make contac with your skin or you could get burned, very unlikely but it could happen.
You need to go all the way to the right (or left) then go down 1" and come back to the other side, then go under again 1" and go back. repeat this process till you get about half way down because anything bellow that is more of a hastle than anything.
you will end your zig zag at the bottom right and then weave your way to the top to about 1" by 1" from the corner.
STEP 3: Repeat Step 2 on the Back
YOu need to repeat the sames steps on the back of the sweater in the same pattern (zig Zag)
STEP 4: Connect Your Copper Wires
Connect your copper wires from the back of your sweater and then connect them to the front using a 9v battery connector.
STEP 5: Attach a Switch
you need to cut one of the wires on your 9v holder and install a switch
STEP 6: Make the Pocket and Put the Battery In
Make a small pocket to hold a Small Tin Can inside it. You dont have to do that but we REALLY recomend you using a small tin box just in case the battery explodes or something ( we have had our sweater for 3 days and it still has nothing wrong)
Attach the switch onthe side of the tin box and place it inside of the pocket. You need to then hook up your battery and put the battery inside the tin box and close it.
STEP 7: Turn on Your Switch and Feel the Heat BABY!
once you get the switch on the ON possition you will feel the coil begin to warm up after a couple of minutes. It worked great and it actually can get pretty hot but it works amazing.
Specially if you wear a jacket over the sweater it works better and it hides the battery. The coil can only be seen from an angle or under extremly bright lights. Enjoy your new sweater and hope you like it ! Dont forget to visit our website at www.hm-innovations.com
28 Comments
Masterchaos98 12 years ago
joehudy 13 years ago
Justdoofus 12 years ago
Short circuiting the battery? Not really, because the battery has something to output to, and takes longer for it to actually get to the battery, it will heat up, but not because it is short circuiting. It would heat up slightly (or even more than slightly) because of the discharge of electrons that were stored in the battery.
bobtannica 13 years ago
HM-Innovations 13 years ago
Ruben
emanb29 13 years ago
Source:
www.gerbing.com
V1x0r 13 years ago
If you get a standard 4AA battery holder and modify it so that the batteries are in parallel and NOT series (so input is still 1.5v) you will output about 20-60v...depending on which method you use. some people get more than that too. and the battiers last longer than your current method.
now, why not go through a little more and make the unit detacheable? take a thin cloth and attach the wiring to that, put some velcro on it and attach on the inside of the sweater. now you have a patch and you can use on multiple clothes.
anyways, hopefully this is helpful for you guys. cool idea too.
BE CAREFUL WHEN WORKING WITH THE JOULE THIEFS...ESPECIALLY IF YOU USE STRONGER TRANSISTERS AND ADD MORE THAN THE 1.5v INPUT!!
enjoy peeps!!
check out overunity"dot"com and look under joule thief
get your basic design from http://josepino.com/circuits/fluorescent_light and modify using overunity.
hope you guys enjoy!!!
V1x0r
bobtannica 14 years ago
wazupwiop 14 years ago
HowToEngineer 14 years ago
kassofcmb 14 years ago
Evidenceremoved 14 years ago
knektek 14 years ago
Doctor What 14 years ago
