Introduction: The First 3D Printable Pintable. Folds Super Small and Stores All the Parts Inside. Ideal for Off-road Use. Holds Up to 2kg
I find it a huge advantage to sit and eat off the ground. To just have some space to set down my drink or to lay down my book. Without any fear for bugs in my drink or a wet cover. Even when I'm camping, or biking, I'll bring my 3D printed PINtable. Lightweight an folds small enough for the side pocket in my backpack. And it holds up to 2kg or 4 pounds.
The top is 23x24cm (almost 10"x10"), large enough to eat alone or drink together :-)
Folded it is 24x12x2cm (10"x9,5"x0,8").
You will need access to a 3D printer and only 305g of filament.
All 3D printable files (including latest modifications) can be found here (PINtable on printables.com).
There is no print-support needed inside the hinges and threads.
Step 1: 3D Print All the Parts
Print the top twice and the assortment of legs and hinges once.
Step 2: Assemble the Hinges
the hinges are assembled easily with a tight snap fit. Don't worry you'll have to push a bit, it will hold.
Step 3: Use It or Store It
The assortment of legs let you choose different table heights between 9cm and 58cm (4"- 23"). All the legs store easily inside the folded table. You can screw the legs together. The thread is specially designed for 3D printing, do not over tighten.
The 2 rectangular holes fit the two rectangular pins. Assemble on the ground with the top down.
