The Gravity Harvester
Intro: The Gravity Harvester
This is a concept based on a idea I had on harvesting gravitational potential energy from rain or any elevated source of water.
The system works by having a pair of tubes that contain a cup each. When the cup is at the top of the tube, a valve opens allowing water to fill the cup. As water fills the cup, it gets heavier and starts to move down the tube. Once at the bottom of the tube a valve opens to drain the water, thus the cup is now lighter and can be pulled up by its partner cup that would be filled with water. The pair of cups moving up and down alternatively via a chain can now power a generator by meshing a sprocket to the chain.
An interesting feature of this design is that you can line up more pairs so you have a row of them and it would improve the output you can get.
Another possible configuration to "stack" the system is to have the pairs where one is upstream of the other thus requiring only one water channel
In this step the 2nd and 3rd pictures show the starting position of each cycle, half way through the cycle the condition is just mirrored where the left side cup is at the top and the right side cup is at the bottom
Here are the screenshots of the design in made in Solidworks
(I really wanted to put in an animation of it working and spent many hours/days getting it to work but my laptop just cant handle it and crashes too much to get any usable animation. but i will try and get one in later)
Please vote for me in the CAD contest if you like this concept, I hope to get some of the parts printed so I can actually test out the device as my access to tools and materials to fabricate this is very limited and quite insufficient.
*Updates*
As pointed out by Kiteman, frictional lose will be an issue, thus maybe the tube can be switched to a pair of guide rails since the tube is only there to guide the cup to the valve mechanisms. As for friction in the chain i guess we just need good lubrication
*Updates*
STEP 1: The Cup
The cup is shaped to push the tube's valve open when its at the top of the tube to allow water to enter through its 2 openings.
When the cup reaches the bottom of the tube a plunger in the tube pushes the cup's valve open and drains the water
STEP 2: Chain
I have also made the chain in Solidworks, pretty straightforward
STEP 3: Final Word
I am really hoping to build a model of this design and I am looking for ways to build it even as I type this out. I hope to polish this design and maybe one day make it good enough to be commercialized and let every home be able to have their own mini hydroelectric station when it rains. I would also like to note this system is not only limited to rainwater, I see its potential to be used in many other places, anywhere a liquid has to travel downwards. This system might even be able to run on fine particles like sand, rice, flour, or even ball bearings. Lets reclaim that vast amount of energy of Mass X Gravity X Height (mgh)
If anyone is interested in expanding on this idea or have questions please feel free to contact me.
Also I am still quite new to Solidworks, so any tips (exp:" you could have done ... instead of ... , that makes it faster and uses less system resources") would be extremely welcome
I hope you like my idea to help with the energy crisis. I would greatly appreciate any constructive feedback
17 Comments
jtpoutdoor 9 years ago
what about something like those autofilling and dumping buckets that you see at swimming pools as a play feature?
HelmutHound 10 years ago
2 thoughts, why not just replace the other cup with a weight? Then when the cup empties at the bottom the weight would reset the location of the cup.
2 this seems to take up a lot more space than a few simple water wheels would. Especially if you are using this "chute collection" method.
You could even use the same cups and chain for the conversion to the water wheel.
michaelgohjs 10 years ago
A) weight = cup, the cup goes down well but might have trouble going back up since we want to turn a generator
B) weight > cup, the cup goes back up well but will go down slower and face more trouble going down
C)weight < cup, well i dont think its going back up
By having both cups change their weight (light when down, heavy when up) we get the best results
let me rephrase that,
the cup has no problems going back up but more water is needed drive it down as opposed to having an empty cup on the other end
bpetno 10 years ago
Anyway in many countries we get lots of rain and I feel its such a waste if it does nothing, many people collect rainwater for various uses, why not harvest the energy as you collect the water.
nbenson1 10 years ago
Thanks
Kiteman 10 years ago
The siphon would stop working when there is no water and require a manual "restart" when there is water right?
Scroll down: http://www.users.waitrose.com/~ttagrevatt/vlav/works_cisterns.html
But I was hoping to find a more efficient method, not sure if this is it as i can't test it or run simulations due to performance.
Thanks for the feedback!
