The Introduction of 5A Constant Current and Constant Voltage LED Driver Battery Charging Module
Intro: The Introduction of 5A Constant Current and Constant Voltage LED Driver Battery Charging Module
ICStation R&D department has develop this wonderful product--5A Constant Current and Constant Voltage LED Driver Battery Charging Module($5.54+Free shipping) recently.Thanks for their great efforts! We will share their achievement with IC fans.We will introduce the function, feature, parameter, diagram,the actual functional test with and an actual application case about this module.Hope you will find the information you need!
Features:
1.Use XL4005 as main control chip.
2.Free to adjust the value of output current,voltage.
3.With threshold to remind you.
4.Small size and especially suitable for narrow space such as automobile car.
Four protections:
1.Output the counter-attack filling and protection
2.Input reverse connect protection
3.Overtemperature protection
4.Short-circuit protection
Parameter:
Module Size:length: 64.5mm Width:28.1mm Height:20mm
way to install:Four 3mm screw
Input voltage:4.5~30V
Output voltage:0.8~30V
Working current:0.1~5A
Working temperature: -40℃~+85℃
Working frequency:350KHZ
Applicable Occasion:
1External power supply
2.Experiment teaching
3.Industrial power supply match
4.Household supply match
Features:
Four protections:
Parameter:
STEP 1: Diagram
STEP 2: Function Introduction
STEP 3: Functional Test
STEP 4: The Actual Application Case:Use This Module to Chare for Lithium Battery.
Tools and components:
Digital Multimeter
Volt Meter Ammeter
Copper Wire
Copper Cylinder
Nut
Pin Header
Screw Driver
Power Connector
Universal Board
Dupont Cable
Lithium battery,battery pack,battery holder
Digital Multimeter
Volt Meter Ammeter
Copper Wire
Copper Cylinder
Nut
Pin Header
Screw Driver
Power Connector
Universal Board
Dupont Cable
STEP 5:
The specification of Lithium battery:3.7V 1060mAh
Module settings:
Input voltage:5.2V
Input Current:1A
Output voltage:4.2V
Output current:300mA
The material for reference:http://www.icstation.com/ebay/IC/All%20data%20modules/3255.zip
Thank you for your visiting! Please feel free to share us your comments. :)
Should you meet any problem, please feel free to contact us.
ICStation Team
Module settings:
Input voltage:5.2V
Input Current:1A
Output voltage:4.2V
ICStation Team
3 Comments
johnyradio 9 years ago
Hi, i purchased this other board with adjustable voltage, but non-adjustable current. Not as awesome as your board!
http://r.ebay.com/JIwHXt
With a heatsink on the chip, the diode burned out while charging a 12Ah li-ion at 4.2V.
I want to try again with a heatsink on the diode, but my buddy says if the board was current-limited, then the diode would not have fried, so i just risk frying the batteries.
Your opinion?
The datasheet for the chip says:
"An over current protection function is built inside. When short
protection function happens, the operation frequency will be reduced from 180KHz to 48KHz."
Does that give any reason for optimism?
Thx!
myouknowwho 9 years ago
Your buddy is right. What you are doing is dangerous. You are not supposed to charge lithium cells with constant voltage. Don't do that, you must not use this board again to charge batteries.
RBA2000 9 years ago
Great job.
Looks like a great module but I wonder if it's as easy as it looks.
How can you for example control it by an Arduino?
