The Muffin Man or Chef Paper Craft (EASY)
Intro: The Muffin Man or Chef Paper Craft (EASY)
This instructable will give you the step by step to create your own muffin man (or chef) out of paper using cheap and easy to use materials. Your chef could be the muffin man, purple pie man, wolf gang puck and many other characters from literature, TV, movies and games.
This is a very easy and cheap creation to add to any classroom lesson. Anyone younger than second grade will need more than one day of work, and pre-cut items might be helpful. Anyone younger than 5th grade you may want to break the lesson up. Do not fear, any K-12 grade level can be successful with this, you just might need to modify what steps they do. Pre-cutting templates for instance might be helpful. Working in small groups may be a good idea. You name it modifications can be made and I'm more than happy to help you come up with those modification. :)
Please see my other paper craft instructables for other ideas as well:
Little Girl Paper Craft
Pirate Paper Craft
Swan Paper Craft
Airplane Paper Craft
Lesson Ideas:
Geography (where the chef, story, recipe originated from, where they were written...learning the continents, oceans)
Basic body terminology (torso, arms, legs, pelvis)
History lesson(s)
Cooking Lesson
Following basic directions
Learning how to write expository text, narrative, instructional
Art lesson for any season
Puppet theater
Learning new key words (these can very from lesson to lesson)
and MUCH MUCH MORE!
I'd love to hear any ideas you might have for lessons!
Pirate Paper Craft
Swan Paper Craft
Lesson Ideas:
History lesson(s)
Cooking Lesson
Puppet theater
and MUCH MUCH MORE!
STEP 1: Materials Needed
Materials needed:
Paper (Construction Recommended)
Glue (Elmers)
Scissors
Hole Punch
Templates
Materials Recommended But Not needed:
Paper Clips
Permanent Marker (many colors or one)
White Paint
White Out
Crayons
Markers
Tooth Pick
Exact Knife
Paper is not the only way this gal could be made, some other thoughts on what you could create this guy out of are listed below:
Clay
Fabric
Paper mache
You name it you could likely use it!
Glue (Elmers)
Scissors
Hole Punch
Templates
Paper Clips
White Paint
White Out
Crayons
Markers
Tooth Pick
Exact Knife
Clay
Fabric
Paper mache
STEP 2: Cut Out the Templates
Open up the PDF, print out and cut out all of your templates needed for your little gal.
I had some old school templates left to me by a former school teacher long ago, I've modified them to make creating paper people easier. This basic design can be used and changed to make other characters. As I work on creating those and different bells and whistles, I'll post those instructions as well.
STEP 3: Head
Time to get out the peach construction paper. After making the pirate I realize a template laid out might be easier than one that had to be cut on fold .
If you like you can draw around the template then cut, I however just hold the template in place then cut away. Do whatever you are comfortable with.
Cut our your template and get your glue ready. On the template you will see a line to place glue to. (the smaller dotted lines). I fold the paper on that line then place the glue.
I glue the top part of the head together, again I used a paper clip to hold it in place. Then glue the neck area together. Again use a paper clip to hold it in place.
Note: It does not matter what color you choose to use for this part, just remember whatever part of the skin is showing should be the same color during the entire project. For this 'able I used peach.
STEP 4: Arms & Hands
Use the template and cut out two arms. Fold on the small dotted line and place glue. Roll the arm and glue it together. Use paper clips to hold it in place.
Cut strips of peach paper and roll for hands. Glue inside the arm.
STEP 5: Legs & Shoes
Take the full leg template and cut out legs in your choice of pant color. Then decided what color the shoes of your chef will be. I went with a plain white. Cut out two.
Put glue on the outside of each leg and roll them together and hold them in place with a paper clip. Place glue all around the inside of the shoe and glue it onto the leg then glue the legs together.
STEP 6: Hat & Head
Cut out the hat pattern in the color of your choice for your chef hat. I decided on white. I also cut out a black mustache and hair as well as reading my marker for eyes and nose details.
For the hair I took a black piece of paper and cut small slits. I then rolled the ends. I trimmed the ends off until I was happy with the length for the back of the hair, then used the pieces I cut off for the side of the chef's head.
You will also notice from the picture when I glued the top of the chef hat on, I turned the head upside down and pushed down. This gave me a nice bow to the hat to get a cartoon like feel chef hat.
STEP 7: Chef Coat
Some people call this an apron, which I think is silly. Real chef's wear a coat. Cut out the coat from the pattern. Glue the edge of the coat and paper clip together. put glue around the head of the chef and place it inside the coat. You can then add details to the coat. I used a hole punch and made buttons out of the same color as my chefs ppants. I then drew on a pocket and a thermometer.
STEP 8: Add the Arms and Legs
Take your created arms and glue them to either side of the chef. Then add a piece of paper that makes a U hape and glue them inside the pant legs. The color here does not matter. Put glue on top of that piece of paper and set your chef on top. Now time to set him aside to dry.
You will see a few different looks of chefs. I made one at work yesterday and gave it away and made the new one tonight. You can see how a few differences really change the look of this little paper guy, I'll likely make a female chef eventually and post her here as well.
I can't wait to see what you come up with! Keep your eye on me for more to come!
Remember You can choose any color paper you like, you might also want to use white paper and color the paper using crayons. Just make sure you color before gluing.
I would love to see your paper doll and hear of his/her adventures. Feel free to ask questions I will do my best to help you out and keep your eye out for more paper crafts from me to come!
9 Comments
craftyv 11 years ago
poofrabbit 11 years ago
porcupinemamma 11 years ago
wilgubeast 12 years ago
poofrabbit 12 years ago
