Introduction: The Original Potato Cannon
In this instructable I'm going to teach you how to build the original hairspray powered potato cannon. Sometims it is also called a potato gun. Making this cannon takes about an hour and $30. The finished gun can shoot potatoes over 100 yards!!!
Step 1: The Materials
Building Materials
-5 feet of 1.5" ABS (DWV) pipe
-2 feet of 3" ABS pipe
-A 3" to 1.5" reducer
-A 3" threaded adapter
-A 3" end cap
-A BBQ ignitor (+1 Screw)
-ABS cement
Consumables
-Cheap aerosol hairspray
-Potatoes or similar legumes
Tools
-Hacksaw
-Drill
Step 2: Assembly
-Cut the 3" pipe to about 13" or a size you prefer (the larger the combustion chamber; the more gas; the more boom)
-Make sure the reducer fits over the pipe
-Spread some ABS cement on the inside of the reducer and outside of one end of the pipe, slide the reducer onto the pipe with a twisting method
-Repeat this for the threaded adapter
-Repeat this for the barrel (5' of 1.5" pipe)
Make sure your gluing is done properly, you dont want it to explode.
Step 3: Install the Ignitor
You probably saw in the last step a silver BBQ lighter attached to the side of the pipe, I tried using this, but it wasnt working, so I bought an $8 ignitor.
Drill a hole in the 3" pipe for the metal lead from the ignitor to fit, mount the ignitor using screws provided, you can slop some glue around the hole to make sure there wont be a gap where the flames will shoot out and burn your arm......
In order to create the arc (spark) to ignite the gas, there needs to be a metal contact between the lead from the ignitor and the metal chasis of the ignitor.
If you mounted the ignitor with bolts into the pipe, bend the metal lead to be within 1/4" of the bolt to make a spark,
I however put another screw in from the other side, but had to run a piece of wire from it to the metal chasis.
Both methods will work.
Step 4: You Are Finished; Firing
Let the cement cure for a couple hours.
Firing:
-Unscrew the end cap
-Force a potato into the barrel (this is easier if you sharpen the end of the barrel with a file)
-Pack it down with a broom, make sure its still inside the barrel, and not the combustion chamber
-Spray some hair spray into the 3" pipe for 2-3seconds
-Quickly screw the end cap back on
-Point it at a 45 degree angle to maximize range and push the ignitor
532 Comments
7 years ago on Introduction
what can you shoot out of it?
Reply 6 weeks ago
anything that fits.
it's called a potato cannon...it shoots potatoes
Reply 6 years ago
the simplicity of that burn was lovely
Question 3 months ago on Introduction
I built my potato gun after watching your video it worked great once I cannot remove the rear cap after firing I cut off the existing one and pvc'd a new fitting and a new screw cap on fire it again and the end cap won't come off
5 years ago on Introduction
Can you cut the 1.5" pipe to 3 feet ,instead of 5?
Reply 1 year ago
I think so, you'll just get less range
Reply 2 years ago
i think it will still fire fine but the potato probobly just wont go so far
Reply 3 years ago
Sure you can. It will reduce the range, though.
Reply 5 years ago
Late, but yes.
1 year ago
me and my frend are doing this for our sience project
8 years ago on Introduction
my end cap blows off, what can i do?
Reply 2 years ago
Drill some holes through the sides of the cap and the end of the combustion chamber so you can stick some nails through. Or just use a ton of epoxy to seal the cap and mount a bottle cap somewhere on the combustion chamber with another ton of epoxy for fast and easy loading, like I did.
Reply 1 year ago
hi frankie
Reply 4 years ago
Consider removing your cap before you shoot it.
Question 2 years ago
Does it matter where I put my igniter? Does the spark nee to be towards the back of the chamber?
Answer 1 year ago
yes it needs to be at the back of the chamber
Reply 1 year ago
no it does not have to be in the back of chamber
7 years ago
Also what will any type if BBQ igniter work
Reply 2 years ago
I used a bare piezo element from a lighter and it still works
