Introduction: The Pocket Bunsen Burner
Warning!
Always be careful when dealing with fire
extra caution is needed when dealing with alcohol flame because they burn blue and are hard to see
Step 1: Gather Peaces
you will need:
1-1" brass tubing adapter
1-penny (can or usa)
1 cotton makeup application pad
isopropyl alcohol (rubbing alcohol)
or
methyl hydrate (engine line antifreeze)
or
Step 2: Stuff Cotton Pad Into Brass Insert
insert cotton pad into brass insert
note: make sure the cotton pads are 100%cotton otherwise it could catch fire and start to melt and release toxic smoke into the air
Step 3: Cap End With Penny
stick penny into end hard using thumb
if it doesn't stay on its one try at a different angle
NEVER USE TAPE OR GLUE
DOING SO MAY CATCH ON FIRE
and you have to replace the cotton pad after about 1 hour of use
Step 4: Add Fuel
add about 5ml of fuel in to the cotton top
to little and you wont get a light
to much and it will leak out the bottom setting fire to everything
SO DON'T OVER-FILL !!!
Step 5: Done! :0)
ignite your new burner with a match or a lighter
it should burn between 10 and 16 minutes depending on the fuel used
