Introduction: The Scorcher Mk2 CAMP Instructions
Ok I gave in to the pressure and made some instructions!
Some parts you want to have handy
Black y clips (the gun uses a lot
Swivel/hinges
Rubber bands
Firing pin
A few cut rods
Orange white and yellow connectors
White black/green and blue rods
Things to note
Every cut blue rod can be replaced with a whole blue rod (the ones in the body can only be whole rods if you don't add the seventh layer)
Now let's begin
And if your wondering why it looks SOO "blue mullet like" with the mech is because I learned ALOT from building his sig 552 (check it out and check out my review of it too)
Swivel/hinges
Rubber bands
Firing pin
A few cut rods
Things to note
Now let's begin
Step 1: Seventh Layers (not Needed)
Note the broken connectors on one layer
Step 2: Inner Layer (5th Layer)
This part is needed (pay close attention to the white rod placement
Make x2
Make x2
Step 3: Handle and Hand Guard
Yes the grey connectors must be cut....deal with it
The blue rods on the handle can be white rods if not adding the seventh layer
Step 4: Inner Frame
Ok so set out your 5th layer (one of them) and prepare to get working
Note replace all cut rods with blue rods of not adding 7th layer
Feel free to add 7th layer on now
Step 5: Stock
Note the two cut blue rods can be replaced with un altered blue rods
Make all of what you see
If there is one in the pic make one if there is two or more make two or more
When connecting the halves of the stock use a blue rod instead of the white one shown
Step 6: Connecting the Stock
The white rod on the top halve of the stock should attach to the black y clip and the swivels should connect as shown
Step 7: The Magazine
You will need 2 cut rods....some sacrifices have to be made
Step 8: Rear Sight
Looks cool don't it??
Step 9: Banding the Pin
It's not that hard (I'm using only a few bands for the demonstration as not to confuse some people)
