The Secret to Darker Screens!
Intro: The Secret to Darker Screens!
Is this you at night? iPhone screen brightness turned down all the way but still blinding? Follow these steps and you can make your screen as dim as you like! (To a point) You'll also be equipped with a handy shortcut to dim or brighten your screen whenever you need to!
STEP 1: Go to Settings
We start easily enough. Find your 'settings' app and tap to open.
STEP 2: Go to General
We're heading to the 'Accessibility' settings here, which are found under 'General'. Go here first.
STEP 3: Open the Accessibility Settings
Now tap 'Accessibility' and we're there!
STEP 4: Go to Display Accommodations
First, we need to set up how dim we want the screen to go when we use the accessibility shortcut. We'll set the shortcut up later. Tap on 'Display Accommodations'
STEP 5: Turn Reduce White Point On
To access the slider for screen brightness, turn on the 'Reduce White Point' slider button.
STEP 6: Set Your Preferred Brightness
Drag the slider to set the value of brightness you want when you use the shortcut we will set up next. I use 90% which is perfect for a completely dark room.
STEP 7: Turn Reduce White Point Off
As you'd probably like to see what you're doing until you need it, turn 'Reduce White Point' off to return to normal screen operations.
STEP 8: Go Back and Open Accessibility Shortcut
Now, go back to the 'Accessibility' options, scroll to the bottom and open 'Accessibility Shortcut'
STEP 9: Tick Reduce White Point
The Accessibility Shortcut is a triple click of the home button. As you can see, it can turn a few different options on. You're interested in the 'Reduce White Point' option. Tap it to tick it.
STEP 10: That's It!
You're all set! Next time you need to get an extra dark screen for some reason, triple click your home button and as if by magic, it gets all dark and easy on the eyes. To reverse this, triple click again! Simples.
10 Comments
Anirudh Ralhan 7 years ago
dmwatkins 7 years ago
dbuckley6 7 years ago
Gluboy 7 years ago
Justas_ 7 years ago
Stragge 7 years ago
thx for the info!
rafununu 7 years ago
Thank you. There's no age limit to learn !
iBrokeit Repairs 7 years ago
DIY Hacks and How Tos 7 years ago
I have this issue all the time. I have a new baby. So I am up late a lot and the screen brightness always messes with my night vision.
