The Swirly Gold Wire Bracelet
Intro: The Swirly Gold Wire Bracelet
Heya!
I realized I had some nice gold wire just sitting there unused among my other craft supplies. And I also felt in need of something to cheer myself up since I haven't been getting as much outdoor time as I used to. And as an extrovert deprived of social interactions and new opportunities, you can guess that - maybe I wasn't doing as well as I could be.
(Anyone else feeling the same way? Or have you been having the time of your life with you, yourself, and Netflix??)
So anyways, I decided to make myself a sunshine-and-beach inspired bracelet today AND I thought it would be nice to share so we could all have a little more sunshine in our lives.
It's quite easy to make - the swirls aren't as complicating as they may seem.
Let's get making!
STEP 1: Optional (but Recommended) - Sketching Out the Reference Shapes:
The first thing I usually do when making jewelry is sketch out the shapes of the jewelry parts on a sticky note. That way, I know what size to make each piece, how to get the exact shape right for each piece, etc.
You could just skip this step and make your pieces without a guide, though personally I take the less risky route and base my pieces off of the sketch + comparing my pieces with each other to ensure my pieces are all similar.
I left some notes about each piece in the picture in case it helps.
STEP 2: Making the Clasps:
I started with making one swirly end of a clasp before curving the wire up and around to make a bit of horseshoe shape and ending with another swirly end.
Then, I repeated the process with the second clasp.
Hammer both pieces on a smooth surface to strengthen the clasps.
STEP 3: Making the Main Bracelet Pieces:
I experimented with 2 methods while doing this, actually:
Method 1:
- Make the innermost swirly bit with pliers
- Wrap the wire around the swirly bit with your hand to make a circle.
- On the final wrap around the circle: Stop halfway to make a little loop above the circle (this is for linking it with the other bracelet pieces later), then continue wrapping the other half of the circle.
- For the second circle, follow the same steps but REVERSE the order: The outer wrap + the little loop first, then swirling inwards.
- Just cut the excess.
Method 2 (possibly the easier method in my opinion):
- Measure out and cut about 18 cm of gold wire.
- Mark the 9 cm point on the wire.
- Follow Steps 1-3 from Method 1 (the first circle should use up about 9 cm of wire).
- Follow the same Steps 1-3 from Method 1, but on the other side of the bracelet to make the second circle.
- Cut the excess.
When you're done one piece, just make another 3 pieces.
And yes, remember to hammer all the pieces to strengthen them.
STEP 4: The Swirly Center Piece
Okay, so it sounds fancy and all.
But really it's just making one circle like in the previous Step, EXCEPT instead of continuing to make a second circle, you make a little loop at the end, chop off the excess wire, and call it a day.
Then, just hammer it up a bit.
STEP 5: Connecting the Pieces With Beads
Start with a 2.5 cm long piece of wire and begin a little loop on one end. Hook it on to the loop of a bracelet piece and THEN close it.
Then, just slid in a pearl bead and repeat the process on the other end of the wire.
Do this with 3 more pearl beads and you will have connected the all the swirly pieces together.
You can always check out the pictures out for details.
STEP 6: Connecting the Clasps With Jumper Rings
If you have golden jumper rings you can use, well great!
If you don't have any jumper rings, here's an easy way I use to make some: wrap your wire around something round and thin (like a thin paintbrush) and cut off the extra.
Make 6 rings total - one for each side of the bracelet. Hammer up each of these.
Link one ring to a clasp, a second ring to one end of the bracelet, and link a third ring to connect both of these rings.
Then repeat with the remaining 3 rings on the other side of the bracelet.
STEP 7: Glue on the Jewel
Well. Just like the title says it.
Take some super glue and glue the jewel onto the center piece of the bracelet.
Boom!
Aaand a note on how to put it on: slightly open the ends of the clasps and slid them into each other (imagine linking two horseshoes together). Then, just close the ends of the clasps again.
STEP 8: You're Done!
Well, what are you waiting for?
Time to put on your sunshiney bracelet and feel like an elegant sea queen.
Now you've got a piece of the summertime right on your wrist to cheer you up through any boring indoor day!
