The Tin Foil Paper Airplane. Any Design You Want.
Intro: The Tin Foil Paper Airplane. Any Design You Want.
This was originially for the Toss It! Speed challenge, which has ended. So this effects the contest in no way.
Recently in 2008, scientists I (GorillazMiko) have discovered that it is possible to use tin foil (aluminum) to make paper airplanes, and it is very easy. Many other people may have known this, but it has not been posted onto Instructables, so yeah, there we have it. There was also a method discovered on how to flatten it out, which I found out with my friend. People may use this method, but I'm not sure. It's not on Instructables, is it? The paper airplanes you design with the aluminum foil could be either very light (a couple of grams), or either kind of heavy, depends on the way you make it.
This Instructable shows you how to flatten out a piece of tin foil paper, cutting it, folding, and making it easy to make your own paper airplane.
So are you ready to fold some planes?
You bet I am.
Let's get to work soldiers.
Please ignore the pictures with the Toss It! Paper. Well, don't ignore it. You need it. It's just that the contest is over, and this was made during that time. Sorry.
You bet I am.
STEP 1: Items.
The items are extremely easy to get.
- A normal US letter size piece of paper. A4 would work.
- Some aluminum paper tin foil paper whatever. Make sure it is BIGGER than the normal paper, unless you have a perfect cutter or something.
- Book, or flat surface. Not too strong. A hardcover book (not too thick) works great.
- X-Acto knife. (Optional)
STEP 2: Comparing, Folding, Tearing.
Now you will compare your paper to the aluminum foil.
It should be a bit smaller then the aluminum, or a lot smaller, depends on the size you got.
Once you do that, fold the longest side first so it reaches up to the paper.
Tear that off, and then do that to the short side of your paper. Tear that part off too.
Then, compare once more. It should be perfectly the same size, or at least close to perfect.
If you have those big cutters with the big blade on the handle thing (which I don't have. My dad has a couple at work I think...), that would work fine.
- This is the step you can use the X-Acto knife if you want.
STEP 3: Flattening Time.
Here is the part where I show you how to flatten the foil out.
Easy easy easy. Put the foil onto a flat surface, probably a table... :P
Not a toilet seat.
Put the book on one edge (not TOO close to the edge), and start sliding it across over and over again.
Flip. Repeat.
Flip. Repeat.
Do it until it's really good. The sides might tend to curl up, but it's okay, flip it over and repeat the process.
Here's a video of it:
Not a toilet seat.
Flip. Repeat.
Flip. Repeat.
STEP 4: Making the Plane.
Here is when you just make your own plane.
The rest of the steps will just show you how to make a classic plane, but you can probably make any design you want.
You have to be VERY careful to not rip the foil when folding. Crease hard, but not too hard, soft but hard at the same time to keep it good.
If you have anymore questions, please ask in a private message or a comment.
Thanks.
Thanks.
STEP 5: Fold, Crease, Unfold.
Hot-dog fold the foil in half.
Be extra careful, and don't forget to constantly (well, every now and then) flatten it out to keep the foil in good condition.
STEP 6: Arrow Folds.
Here is the first two arrow folds you will be doing.
Fold both edges to the middle so they are both perfectly (at least very close) aligned. Once you do that. crease the folds so they can stay in place.
Don't forget to flatten it out every now and then!
STEP 7: More Arrow Folds.
Here's the last two arrow folds.
Fold the edges of the arrows you just folded up to the center, both sides, so those are perfectly aligned. Always remember to look at the pictures for more help!
As you can see, the paper is very crinkly in some images. That's why you always have to flatten it out to keep it nice!
After these two folds, flip it over. Then move onto the next step.
STEP 8: Finishing Up.
Now, fold both sides together, so they are even.
Then, you will have to fold both wings down to make them parallel.
Fold them down so they are aligned neatly with the bottom part of the plane.
Then, you're done!
Just remember to always flatten it out constantly, and don't rip the foil or fold/ crease too hard.
Any design would work, I have 2 in the end of this step that work GREAT.
The classic, and another classic.
Post your results in comments, I would love to see them!
Have fun flying your planes!
Thanks for checking out my Instructable!
-GorillazMiko
Then, you're done!
-GorillazMiko
42 Comments
pizzaonmychest54 6 years ago
wow,. i love this so muhc. tears were brought to my eyes.s,
also gorillaz is my favgorite singer i love hsi song can you feel it (i think super junior covered it)
Booce bungalow 9 years ago
Screamo 13 years ago
Derin 14 years ago
For those that do not know, duraluminum is an alloy used in making aircraft.
bassclarinet23 14 years ago
Derin 14 years ago
jibatsu 14 years ago
CameronC 14 years ago
Chromatica 14 years ago
joejoerowley 16 years ago
GorillazMiko 16 years ago
Example: Eggs.
, <-- Comma. Pretty obvious. Put two of those, space, words, space, two more, and then it's small, but down.
<-- Caret. Or Carat. Forgot. Anyways, put 3 of those, space, words, space, three more, and that's small words, but up.
Example: Down. Up.
sjs229 15 years ago
codongolev 15 years ago
freakmonkey 15 years ago
funwithfire325 16 years ago
struckbyanarrow 16 years ago
