The Tome of Infinite Knowledge: a Book-styled Netbook Case From It's Own Box
Intro: The Tome of Infinite Knowledge: a Book-styled Netbook Case From It's Own Box
After the downfall of Circuit City's Brick-and-mortar stores, I was able to pick up an Averatec buddy Netbook (a re badged MSI Wind). Wanting a decidedly steampunk case, and running low on funds, i decided to make one out of what was handy:
Materials:
The box it came in
Brown faux leather fabric (local craft store, or even some big box stores)
Cheap cotton clothesline
2x sheets of white paper
Delicious, delicious White glue
Tools:
Boxcutter
Hammer
Caffeine
Techniques Used:
Cutting straight lines
folding fabric
smacking things with a hammer
Glue use
This isn't so much a definitive guide how-to, it's closer to a how-i-did-it guide. Also, I'm going off memory for this guide, the creation of the original was almost mystical. After getting everything unboxed and working properly, we, like most college age people, got really bored. After an errant comment of "I should so make a hollowed out book for this to live in" Inspiration struck like a bag of bricks from low earth orbit. It took two nerds 40 Minutes to complete construction and overnight for the glue to dry.
Materials:
The box it came in
Tools:
Boxcutter
Hammer
Caffeine
Techniques Used:
folding fabric
Glue use
STEP 1: The Part Where Photographic Images Would Help a Lot, But Seem to Be on Break
Netbook boxes are like pie. After opening, you have a flakey topping of manuals, an ever so delicious netbook filling, and a filling enhancing but bland on it's own power supply crust. between the power supply and the netbook is a cardboard tray, that is what we're going to need. Depending on your manufacturer, the tray may be glued in. If so, carefully cut the tray out at the right-angle seams. The box should have a half inch or so "Crumple zone" around the netbook during shipping. Cutting in the crumple zone should release the tray, and leave most of the rest of the box intact. Now, you should be able to cut the remainder of the box so the long sides of the box fold out like a cross
I apologize for the paintbrush diagrams littering this article, i fail at documentation
STEP 2: Trimming and Cutting
time for the hardish part. Take the netbook and put it back in the cardboard tray we cut out of the box. Now, place the tray and netbook on the cardboard cross. fold the cardboard cross over the top of the netbook and check the fit. Trim the edge that gets folded over completely off, this lets the back of the book get closer to the lid, and close lower. This step is going to take a while to get right.
I trimmed off one of the side edges off completely to allow access to the power jack and let the fan blow easier while in the book.
STEP 3: Fabric
time for the fabric. I have some of this faux leather leftover from another project and thought it would be perfect. You could use any fabric you want , but for the Arcane feeling, i thought the leather was a good choice. The fabric i used was deceptively stretchy if you want a taunt cover material, you may have to pad the cross/lid to get your desired effect, or you could keep the two tabs left over form cutting the lid material, folding them over onto the top the applying the fabric. I was happy with the slack cover, so i just measured out 2 to 2 1/2 inches from the edge of the book and cut in nice straight lines.
STEP 4: Attatching the Fabric: Electric Gluebaloo
With the fabric now cut to size, add some glue to the inside edge of the lid, fold over the fabricinto the glue, and add weight. If you want an even better hold, and have a sewing needle and good, strong, and complementary colored thread, you can sew through the cover and fabric for an even stronger hold. Remember to leave a little slack at the spine, so when it's fully closed it doesn't damage the fabric by pulling too taunt. Once the fabric is in place, measure a half inch off the cover of the book and trim some white paper to match. Cover the inside edge of the lid with white glue and attatch the paper. Once dried, the paper will help hold everything together and look more book-like
STEP 5: Metal Corner Protectors, Double Duty
The metal corner pieces are from the local craft store, i think they're designed for decorative boxes I bent them over the edges then hammered them down. Besides looking good, they hold down the problematic corners. Crushing them flat with a hammer adds a lot o f strength to the corners, just be careful with the finish. I also discovered that if i trim off one of the "arms", i could get it flatter
STEP 6: Rope?!
The clothesline is a cheap brand i bought to cover cables in a vintage lamp i was repairing. The outside is made of braided cord like you'd expect, but the inside, on the other hand, is a 2 inch ribbon of fabric folded in on itself. By carefully pulling the cloth out from the center, i had 10 feet of a gauze ribbon (that also looks a lot like paper) Measure the outside edge of the tray on the sides you'd see and add 4 inches to anchor it to the lid. apply glue liberally to the outside of the tray and put the gauze around the perimeter. glue to the inside edge of the book on both sides. you may want to leave some slack on the side where the hole is so the fabric will move easily out of the way when you want to plug in the netbook
STEP 7: Glue Time
once the tray is trimmed the way you like it and the lid has dried, slather the bottom of the tray with white glue and get it where you want it. Make sure the lid still closes. For extra strength, put something heavy on top of the tray as it dries. For even more strength, you can do step 7 out of order and glue the gauze around the tray first so that the glue meshes with it's fibers, increasing it's strength
STEP 8: Holy Crap, I Think It's Done!
If you somehow managed to get through this atrociously written article and something has been made other than a mess, i congratulate you. Feel good for making something despite my badly written instructions.
14 Comments
mycroftxxx 11 years ago
I plan on doing the project once more, and this time I hope to make full use of the laser cutter at the local hackerspace. I plan to break down and rebuild the battery casing, and to mount it in the spine of the book, covered by one of the laser-cut living hinges. I will probably post my project log here once it's complete.
I am very glad to not be the only one doing this.
pennyd 13 years ago
jrn11 14 years ago
Mr. Headcrab 14 years ago
cyberfux 15 years ago
cyberfux 14 years ago
ScubaSteve 14 years ago
reedz 15 years ago
SuperCoPilot 14 years ago
j0j0xn 15 years ago
whatsisface 15 years ago
